la mouche
#1 Posted : Wednesday, April 6, 2011 3:03:46 AM(UTC)
la mouche
Hello Tim,
There is a bug with the option to maintain vertical (match vertices) in the solid skin tool.
http://screencast.com/t/Rps5xtE2Jxv
Thank you
Antoine
solidskin.sfx (474kb) downloaded 4 time(s).
la mouche
#2 Posted : Wednesday, December 7, 2011 2:58:06 AM(UTC)
la mouche
hello tim?
I'd like an answer to my question please.
thank you
Antoine
#3 Posted : Wednesday, December 7, 2011 4:04:18 PM(UTC)
Hello Antoine
The match vertices option turns on/off the ACIS vertex matching algorithm which ensures that all profiles consist of the same number of edges. Profile edges are then internally split where additional vertices are needed.
This does not have to do with maintaining a vertical slope. I believe what you are seeing is the skinning algorithm blending between different profile heights. I suspect you are wanting a sweep vs skin behavior.
