beagle
#1 Posted : Tuesday, November 13, 2018 5:15:12 PM(UTC)
beagle
Belgium
Viacad-pro. V11.0.0 build 1417
OS= Mojave 10.14.1
I have a problem.
I open an already existed file and make some changes to the drawings.
Then I like to save it.
When click on the "Save button" I got following message:
File may have been modified by another user! Do you want to write it anyway ?
When answering by "Yes"
I got following.
Could not save datafile. Please check that you have permission on this folder or file
/user /xxxx/desktop/yyy.vcp
I'm the only user on this MacBook Pro. and got this kind of message not when working in Viacad Pro V10
Ship modelling is not a hobby, it has become a way of live.
beagle
#2 Posted : Wednesday, November 14, 2018 11:02:55 AM(UTC)
beagle
Belgium
Each time I change the Privilege to "Read & Write." (via finder)
Next time I open the file and want to save. got again the same messages as above.
WhenI go see the status of the the privilege , they are changed to read-only (dropbox)
Obviously it is Viacad pro who change the status ( It was ,in this case) the only program used.)
#3 Posted : Wednesday, November 14, 2018 1:03:24 PM(UTC)
Hello beagle
Where are you saving the files to local hd or cloud?
beagle
#4 Posted : Friday, November 16, 2018 4:21:33 AM(UTC)
beagle
Belgium
OS-Mojawe . Viacad pro V11 build 1417
I'm saving locally on desktop.
I have remarked that a "SAVE AS" works.
He only ask if it may overwritten.
by "SAVE" I got the errors.
PS-1. When using " Save" some way or another, the file-privileges are changed by viacad.
just before opening the file it is Write & read. When saving it becomes read only. So I find that a big bug.
PS.-2 As a newbie to viacad.. Is it normal that there are so many bugs or things who do not work properly?( like - Save -spline .... and may be others who I have not used?) and that you got no answer when contacting "Encore" via mail to report errors?
Edited by user Friday, November 16, 2018 4:25:04 AM(UTC)  | Reason: typing errors.
beagle
#5 Posted : Wednesday, January 2, 2019 12:29:03 PM(UTC)
beagle
Belgium
I still have the problem. and no Solution.
OS= MOJAWE. Viacad-pro V11 build 1417
I got this problem since I upgrade to V11 !!!!
Do the following.
Open a new file…. p.e. test-1
Draw some line in it.
Save it via “Save” to desktop
Close Viacad.
Observe the rights = "Read & write"
Open viacad again and load the new file
Then draw a additional line in the drawing.
And do a “Save" again…
You got following warning.
I do “YES"
File is not saved. !!!!!
Open test-1 again and draw a line in it.
You can save the file with “save-as”. p.e. test-2
Then close viacad
Then open test-2 again
And to a “Save" again…
You got the same warnings as above and file is not saved.
I can not open a n already existed file , ad some lines to it and try to save... The only way is via "Save-as".
Who has the same problem ????
/Users/beagle/.Trash/Screenshot 2019-01-02 at 19.16.47.png
/Users/beagle/Desktop/Screenshot 2019-01-02 at 19.17.02.png
Edited by user Wednesday, January 2, 2019 12:31:30 PM(UTC)  | Reason: Not specified
beagle attached the following image(s):
Screenshot 2019-01-02 at 19.16.47.png (62kb) downloaded 0 time(s).
Screenshot 2019-01-02 at 19.17.02.png (91kb) downloaded 0 time(s).
beagle
#6 Posted : Wednesday, January 2, 2019 1:19:12 PM(UTC)
beagle
Belgium
Thanks Todd..
With Mojave and build 1420 it works ....
