I have a question.
I'm a ship model builder who likes to make the lines of the model ships in a Cad drawing.
I'm new to the forum and new to viacad.! (In the past I was drawing first with "Vectorworks" and then with "High-Design v.1.xx)
IN 2D I want to draw the vertical section lines of a ship hull.
So I have at regular distance some well defined point (X-Y axis).
See examples
Now I have connect these point with a straight line. (blue lines )
But I want to draw a fluent line thrue these points.
How do I perform that in Viacad.?
Edited by user Saturday, November 17, 2018 4:58:12 AM(UTC)
Ship modelling is not a hobby, it has become a way of live.
I expect that you're looking for interpolated spline through your coordinates.
OK I will try it with Spline.
help !!! spline seem to do the trick but.. I can pick 5-6-7 points and after the last point = 1 click To end the line : -right click= my spline disappear -Esc = Idem. -Double click = idem. so what is the trick to end a splines that is stay visible.
Originally Posted by: beagle help !!! spline seem to do the trick but.. I can pick 5-6-7 points and after the last point = 1 click To end the line : -right click= my spline disappear -Esc = Idem. -Double click = idem. so what is the trick to end a splines that is stay visible.
Hello
Is it possible that the spline is there and hidden. Try the show all button.
Found in viacadtripsTrickls Right Button (Optional) Press to terminate a sequence of points (spline and polylines) I don't know but this does not works for me! most of the times I cannot terminate the Spline it always disappears. Any body can explain in sequence how to draw an spline true a multiple of checkpoints and terminate it so that is is not disappeared
beagle-
select the "interpolate spline" tool under DRAW; select each of the points in order; after last point press the "Esc" button on your keyboard (Windows operating system).
Art
[email protected]
sorry but it do not work. at the end I click last point and then "ESC" and the spline disappear I do the same with at end right click = same result. I do the same with at the end double click. = same result... I wil note that I work with OS-High Sierra. and a French-keyboard and not a Qwerty... !!! (Now I wrote this... I have the same problem with an other program who at the end didn't take in account different keyboard layout. - May be this is the same kind of bug?)
Originally Posted by: beagle sorry but it do not work. at the end I click last point and then "ESC" and the spline disappear I do the same with at end right click = same result. I do the same with at the end double click. = same result... I wil note that I work with OS-High Sierra. and a French-keyboard and not a Qwerty... !!! (Now I wrote this... I have the same problem with an other program who at the end didn't take in account different keyboard layout. - May be this is the same kind of bug?)
Hello beagle
Do you have a 3 button mouse? The mouse actions should be ok, even if the keyboard is different. What happens when you double click on the last point to terminate the spline.
Always the same i see the spline when drawing and at th end they disappear when double click with mouse.sometimes ifound that moving from right to left to make the spline the double click at the end works
beagle Do you have another mouse and keyboard you can try, if it works sometimes it could be a issue with your keyboard or mouse. Regards Jason
beagle Can you post a sample file of 1-2 groups of points so we can try based on the geometry you are using. Regards Jason
this is the file
take the layer nw-hor (bleu lines) and follow one of the lines.
OS-2018-01.vcp
(1,476kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
beagle-
loaded your file into SharkCAD Pro (my ViaCad 7 is out-of-date) and had no problems. see attached image. suggest you draw one spline per layer to facilitate finding all of the correct points per spline.
Art
[email protected] Art Smith attached the following image(s):
(18kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
sorry guy's. but it do not works with an "Azerty" - French keyboard. and I do not want to buy a other Mcbookpro only for Vioacad to be able to draw a line. Viacad wil not accept the "dubble click "nor the esc. and all my attempt to draw a Line are fail.
Hello What mouse are you using? Regards Jason
a apple blue-tooth mouse.. PS even with V11. it do not work. If possible I wil try to make a movie.
hoi I have found some thing. If I draw a spline from Left to Right ( multiple points) and at the end I dabble click the left mouse button? the line disappear. But When I draw from Right to Left, the same drawing , the same multiple points, and at the end I double click the left mouse button.... Then The SPLine is draw. and I can see it into the drawing..
I have the answer !!!
from tech support.
When using the spline tools you can not click and drag at any point in placing the control points. If you do when you go to finish the line, it will disappear. Make sure you click the first point, then lift the mouse button before moving to the next point to click. Repeating these steps with all the points. Edited by user Saturday, November 17, 2018 2:15:51 AM(UTC)
2 users thanked beagle for this useful post.
murray on 11/17/2018(UTC),
jlm on 11/17/2018(UTC)
