Solid Modeling
unable to create a counter bore
hi, i tried to create a counter bore with equal diameter and bore values on a solid (see picture).
viacad pro build 1359 (mac) returns an acis error, even if i decrease the bore value.
viacad pro version 8 works fine with equal diameters, so i presume a bug in v10?
see my solid as an acis sat file in attachment.
any tipps?
edit: please rename .vcp to .sat (.sat seems to be forbidden)
Edited by user Thursday, August 16, 2018 12:14:41 PM(UTC)
Adapter_1v5.vcp
(8kb) downloaded 5 time(s). rokoko attached the following image(s):
(116kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 171 times Was thanked: 157 time(s) in 107 post(s)
I put a counterbored hole on the .sat, only it's in decimal, not mm.
A little on the small side, but the example is there, as to what dimension goes where.
The first data entry is the depth of the hole, second, hole diameter, third,
counterbore depth, and then counterbore diameter.
Edited by user Friday, August 17, 2018 8:18:18 AM(UTC)
Counterbore.sfx
(23kb) downloaded 1 time(s). Counterbore2.sat.vcp
(11kb) downloaded 2 time(s). L. Banasky attached the following image(s):
(67kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
thank you. it is working if "bore" is larger than "diameter". kind of confusing. in version 8 it was no problem to use identical values here. funny.
Solid Modeling
