L. Banasky
#1 Posted : Friday, August 3, 2018 2:24:48 PM(UTC)
L. Banasky
Was thanked: 157 time(s) in 107 post(s)
When I saved this file, there were no extra parts, the yellow angles, they are from
another file.
The next time I opened the file, the yellow angles were there, the original file
that had the angles, only had 4 of them.
Has this happened to anyone else?
Bracket.sfx (2,165kb) downloaded 2 time(s).
Extra Parts.jpg (82kb) downloaded 2 time(s).
horst.w
#2 Posted : Friday, August 3, 2018 3:11:23 PM(UTC)
horst.w
Its the same when I open it in VC10
Perhaps you had hidden the angles first, later Show All, than they come up.
H.
rokoko
#3 Posted : Saturday, August 4, 2018 2:30:33 PM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
when i had such a problem, it helped to activate "clear undo on save"
BillB
#4 Posted : Sunday, August 5, 2018 4:26:25 AM(UTC)
BillB
Yes, but ViaCad used to clear the undo when it did a backup save. Is this still the case?
Bill Bedford
Viacad Pro 11 (11417)
OS X 10.13.6
