Hi All
Just want to check if this is right
if I place a block primitive (or any other type) and set the sizes, I can move the block and still control the parameters but if I copy the block then I cant change the block parameters
assy.vc3
(22kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 46 times Was thanked: 308 time(s) in 207 post(s)
Have you tried the copy with history? Right click the block somewhere in that list is duplicate with history, does this work for you? Cheers
