sainttimothy
#1 Posted : Wednesday, June 13, 2018 10:25:02 AM(UTC)
sainttimothy
I have a step model that isn't oriented correctly for exporting to cam program for machining. Is there a way to change the X/Y/Z orientation?
#2 Posted : Wednesday, June 13, 2018 10:29:53 AM(UTC)
Hello
Yes you can use the rotate tool to re orient a part. You will need to determine the details by how the model is currently positioned.
sainttimothy
#3 Posted : Wednesday, June 13, 2018 10:42:09 AM(UTC)
sainttimothy
Can you elaborate? I have a part which is currently oriented with z as the side rather than z as the top. I need to orient the part so Z is the top (coming out of the screen at me)
#4 Posted : Wednesday, June 13, 2018 10:53:47 AM(UTC)
Select rotate tool
Select the object
Change drop down to rotate y or rotate x depends on the rotation point you want to use.
Pick a point to rotate about
Change angle to 90 deg. hit enter
Edited by user Wednesday, June 13, 2018 10:58:55 AM(UTC)  | Reason: Not specified
