Import/Export
importing Illustrator DXF file into ViaCad 2d/3d V9
When I import an Illustrator DXF/DWG file into ViaCad 2d/3d program and try to us extrude, I get a message saying there are overlapping curves and to delete them before I can extrude the image. What does it mean overlapping curves and how do I get rid of them?
Hello There are curves that overlap others so there could be duplicates. You can right click on a part of the profile and use select chain tool to Find stray lines. Also click on each part of profile and look for issues. Regards Jason
thank you for the quick response Gerald
Import/Export
