digitalphaser
#1 Posted : Wednesday, April 25, 2018 7:57:17 AM(UTC)
digitalphaser
I have long intended to discuss this problem.
1. After about 200 operations, the program crashes(rendering of UI, impossibility to save the result etc...).
How can I avoid this problem?
2. After the file is reopened, the reference images disappear(only empty placeholder).
Is it possible to restore linking or embedding of image? If I upload a new image: Is it possible to apply the attributes(size and position) of a lost image to a new one?
Currently I use SharkCad Pro v1368.
#2 Posted : Wednesday, April 25, 2018 8:55:26 AM(UTC)
I've had my text boxes go all weird on me like yours. I was going to ask about stability as well. I converted a little block yesterday 50 x 50 x 30mm. Has 4 holes in it and rads around the top edge. I waited for around 30 minutes before I gave up and crashed the session. All I asked it to do was change to surfaces?
So you're seeing crashes after many more operations?
digitalphaser
#3 Posted : Wednesday, April 25, 2018 9:10:43 AM(UTC)
digitalphaser
I certainly did not count the number of operations. :)
But I set the "Autosave" after 30 commands. Autosave is repeated at least 10 times. So. Yes, it means about 300 operations. ;)
#4 Posted : Wednesday, April 25, 2018 9:13:04 AM(UTC)
After the file gets in this state.
Reboot pc
Open the last backup before this happens
Then see how long till it happens again.
digitalphaser
#5 Posted : Wednesday, April 25, 2018 9:25:00 AM(UTC)
digitalphaser
...Reboot pc
Then see how long till it happens again....
Oh! This is not an easy way. :) In principle, I do not care how many operations. It's bad that it is happening. With 9. version was also the same.
Files opened normally. Only lost images are unnerving. Honestly...
#6 Posted : Wednesday, April 25, 2018 9:40:54 AM(UTC)
...Reboot pc
I am asking you to try this not as a workaround but a way to try and understand what is happening so more data is available. A file just before this happens and then the repeatable steps allow the issue to be traced and resolved by the developers.
digitalphaser
#7 Posted : Wednesday, April 25, 2018 11:00:20 AM(UTC)
digitalphaser
Do you mean send a file to punch support?
