Solid Modeling
pipe with more different sections - wow! (#3187)
hello Tim
is it possible to add soon, a function to create pipes, with different sections?
Indeed it is very difficult to follow a section on a path, because it is not "normal" to the surface.
example: with non-planar paths.
http://screencast.com/t/NDJhNjdkZmMt Thanks
Antoine
Thanks: 140 times Was thanked: 124 time(s) in 84 post(s)
Say, Antoine, That's a NEAT demonstration! It makes me think there are ways to design screw propellers or worm gears or duct fan. Even an earthdigger machine... Thanks!
Antoine, have you had a play with the new "Extend Bend" tool yet in Shark V7? (codename : dum dum dum dum get out of the water angangangang ahhhhhhh)
It's in the bend palette - it's a pretty cool tool - and doesn't care what profile you are extruding
Here, you can see my new design for a periscope for Elton John
Granted, it is limited to radius bends for now ... however ...
... I was using it yesterday to do a simple sheet bending job .. and I got a surprisingly good result from it !
(180kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: jol Antoine, have you had a play with the new "Extend Bend" tool yet in Shark V7? (codename : dum dum dum dum get out of the water angangangang ahhhhhhh) It's in the bend palette - it's a pretty cool tool - and doesn't care what profile you are extruding Here, you can see my new design for a periscope for Elton John Granted, it is limited to radius bends for now ... however ... ... I was using it yesterday to do a simple sheet bending job .. and I got a surprisingly good result from it !
You related to Marty Feldman by any chance?
Martin.
(14kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
he looks like a sheep I know
note : know, not 'know' : )
Hmmm... And you're Welsh too.
hello, sorry but ?
Quote: It's in the bend palette
I do not know where it
have you a print screen from this palette please?
Antoine
here it is Antoine !
(59kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
hello, actually it works only with radius bend. Antoine
hello,
Thanks Blowlamp,
I take your file to my argument:
your examples are simple because they are on flat paths.
in fact, my real question is ...:
[COLOR="Red"]Tim? can you implement in a NEW function pipe ---> as the new function reference volume on the face, as (duplicate path)? to avoid the section twist on the path to normal and remains the face of the volume on which the path is placed?[/COLOR]
see my demo.
http://screencast.com/t/NDQ3Y2IzYz cordialy and thanks for your participation.
Antoine
Antoine. In my opinion that is a bug isn't it? I can't see any reason why it should twist like that - it should surely retain its orientation throughout the curve. I also notice in trying this for myself that negative numbers in the Twist option for this command don't seem to work. Martin.
the problem is the definition of the spline nonplanar. nothing was forced to behave (direction, curvature) as we want .... Antoine
Solid Modeling
