NeuTechFLA
#1 Posted : Wednesday, March 7, 2018 12:31:55 PM(UTC)
NeuTechFLA
I am trying to change the shell from 3.0mm to 3.5mm. Is this impossible?
NeuTechFLA
#2 Posted : Wednesday, March 7, 2018 12:36:33 PM(UTC)
NeuTechFLA
Once again, 26 seconds after I post, I find the answer. Sorry for the bother.
Edited by user Wednesday, March 7, 2018 12:38:37 PM(UTC)  | Reason: Not specified
#3 Posted : Wednesday, March 7, 2018 12:37:21 PM(UTC)
Hello
Their depends on what geometry was modified after the initial shell. You can suppress features in the tree and try to change shell and then unsupress.
It really depends on the geometry interactions. If you post a file someone can look at it closer.
horst.w
#4 Posted : Wednesday, March 7, 2018 12:46:15 PM(UTC)
horst.w
No problem, it is running fine for me.
horst.w
GER
thanks 1 user thanked horst.w for this useful post.
NeuTechFLA on 3/7/2018(UTC)
NeuTechFLA
#5 Posted : Thursday, March 8, 2018 7:00:35 AM(UTC)
NeuTechFLA
Somewhat different.
