Thanks: 183 times Was thanked: 159 time(s) in 109 post(s)
I'm trying to model a twisted rope, best I can do is a twisted square.
Would appreciate any help.
Forgot to mention, this is a Mission Critical Project,
part of a 3D print job for my Grandaughter.
Edited by user Thursday, February 22, 2018 9:47:18 AM(UTC)
Twist.sfx
(369kb) downloaded 5 time(s). L. Banasky attached the following image(s):
(23kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
You can send a helix around a diameter. Then sketch up the shape you need and set aside a good few hours for tweaking :-)
<<<<<set aside a good few hours for tweaking :-)>>>>> Thanks, Tried that, only a few hours? Larry
Ha ha, yeah well maybe a few more. I've had a quick play, and because you can allow intersections with the solid sweep, that worked better than the surface sweep. Adjusted thw pitch and such, and you can get something close to what you're looking at, but that's when the tweeky starts :-)
just a suggestion..
used "explode curve" tool 4 times on the 4 edges of the twisted object. next make the ropes by pipe tool to the 4 resulting curves
Edited by user Thursday, February 22, 2018 2:22:08 PM(UTC)
Twist01.vcp
(316kb) downloaded 6 time(s). rokoko attached the following image(s):
(140kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked rokoko for this useful post.
FYI - the tweak tool is located right below the style filter
Edited by user Thursday, February 22, 2018 3:28:00 PM(UTC)
1 user thanked Jolyon for this useful post.
Thanks Rokoko,
That worked great, you saved the day, all I had to do was trim and export as an .stl
(63kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
