L. Banasky
#1 Posted : Thursday, February 22, 2018 9:29:33 AM(UTC)
L. Banasky
Was thanked: 157 time(s) in 107 post(s)
I'm trying to model a twisted rope, best I can do is a twisted square.
Would appreciate any help.
Forgot to mention, this is a Mission Critical Project,
part of a 3D print job for my Grandaughter.
Edited by user Thursday, February 22, 2018 9:47:18 AM(UTC)  | Reason: Not specified
Twist.sfx (369kb) downloaded 5 time(s).
Twisted Rope.jpg (23kb) downloaded 6 time(s).
#2 Posted : Thursday, February 22, 2018 10:10:40 AM(UTC)
You can send a helix around a diameter. Then sketch up the shape you need and set aside a good few hours for tweaking :-)
L. Banasky
#3 Posted : Thursday, February 22, 2018 10:30:55 AM(UTC)
L. Banasky
<<<<<set aside a good few hours for tweaking :-)>>>>>
Tried that, only a few hours?
#4 Posted : Thursday, February 22, 2018 10:37:55 AM(UTC)
Ha ha, yeah well maybe a few more. I've had a quick play, and because you can allow intersections with the solid sweep, that worked better than the surface sweep.
Adjusted thw pitch and such, and you can get something close to what you're looking at, but that's when the tweeky starts :-)
rokoko
#5 Posted : Thursday, February 22, 2018 2:16:43 PM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
just a suggestion..
used "explode curve" tool 4 times on the 4 edges of the twisted object. next make the ropes by pipe tool to the 4 resulting curves
Edited by user Thursday, February 22, 2018 2:22:08 PM(UTC)  | Reason: Not specified
Twist01.vcp (316kb) downloaded 6 time(s).
L. Banasky on 2/22/2018(UTC)
Jolyon
#6 Posted : Thursday, February 22, 2018 3:26:03 PM(UTC)
Jolyon
FYI - the tweak tool is located right below the style filter
Edited by user Thursday, February 22, 2018 3:28:00 PM(UTC)  | Reason: Not specified
thanks 1 user thanked Jolyon for this useful post.
L. Banasky
#7 Posted : Thursday, February 22, 2018 3:39:21 PM(UTC)
L. Banasky
Thanks Rokoko,
That worked great, you saved the day, all I had to do was trim and export as an .stl
