Solid Modeling
creating a solid from a non-planar surface
looking for help or ideas on how to create a solid from a
non-planar surface.... the attached collage shows the current geometry. I can draw the desired "surface" with a two rail sweep of a line but can't for the life of me see the path forward to a solid.............
thanks!!
Art
artesmith@earthlink.net Art Smith attached the following image(s):
(62kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
found the thicken tool; all's well!!
Art
Art Well found !! FYI - Extrude by distance will not work with a non-planar surface However - Extrude by Vector will work No idea why these should be different, but they are Jol
Solid Modeling
