Jolyon
#1 Posted : Tuesday, November 14, 2017 4:54:06 PM(UTC)
Jolyon
Hi
(I’m trialing Affinity Designer)
Both Illustrator and Designer import a PDF as a picture - is this right ?
[Illustrator saved in a legacy format (v8) works fine as ever]
However when saved in a recent (PDF based?) format … and imported using the Illustrator 9+ option … only seems to come through as a ‘Picture'
Same with Designer (saved out as a PDF)
What am I doing wrong ?
Jol
Jolyon
#2 Posted : Wednesday, November 15, 2017 3:00:08 AM(UTC)
Jolyon
OK - EPS export from Illustrator or Designer should give me lines and splines I can use in 3D
However, it just flattens the data into a 'Picture'
Illustrator 9+ Import also does this ... which is wrong to my mind !
If I'm importing data from Illustrator 9+, I want to use that Illustrator data - not just see a 'Picture' of it !
(Importing data via Illustrator v8 or via DWG works fine of course)
Can we get vectors transferred via EPS ?
Can we label Illustrator 9 Import with ... 'Imports as flattened Picture' - so people can understand what it does
Jolyon
#3 Posted : Wednesday, November 15, 2017 3:00:41 AM(UTC)
Jolyon
Jolyon
#4 Posted : Wednesday, November 15, 2017 3:02:20 AM(UTC)
Jolyon
It's my understanding that PDF can carry vector lines and splines
Why can't I import lines and splines in a PDF file
... again, it gets flattened to a 'Picture'
Nick R
#5 Posted : Wednesday, November 15, 2017 3:26:00 AM(UTC)
Nick R
I've had the same problem with Illustrator 9. Illustrator 8 usually works but is very slow importing. I usually export from Illustrator as DXF, using the latest option available. This will bring the vector info in to Shark.
Nick
Claus
#6 Posted : Friday, November 17, 2017 2:34:05 PM(UTC)
Claus
Denmark
I agree it would be nice to import vectors from pdf files. I usually save as Illustrator 3 and import that. But other vector illustration programs don’t export in ai format and I would love to loose Illustrator.
Claus
Guest (6)
