Antoine
#1 Posted : Wednesday, October 18, 2017 3:51:44 AM(UTC)
Antoine
Switzerland
Was thanked: 32 time(s) in 26 post(s)
Hello Tim and co
there is a bug with the intersection option.
Thank you
Edited by user Wednesday, October 25, 2017 2:14:24 AM(UTC)  | Reason: Not specified
Antoine attached the following image(s):
Antoine
#2 Posted : Wednesday, October 25, 2017 2:16:07 AM(UTC)
Antoine
Switzerland
it's not clear?
#3 Posted : Wednesday, October 25, 2017 7:19:14 AM(UTC)
Was thanked: 171 time(s) in 103 post(s)
Originally Posted by: Antoine Go to Quoted Post
it's not clear?
The pipe is clearly blocked...
(c'est bouché!)
BillB
#4 Posted : Thursday, October 26, 2017 2:30:34 AM(UTC)
BillB
Seems to be true for all pipes where the internal diameter intersects.
Bill Bedford
Viacad Pro 11 (11417)
OS X 10.13.6
#5 Posted : Thursday, October 26, 2017 4:40:35 PM(UTC)
Yes this is a limit to the tool. If the path self intersects, it cannot subtract the inside. Same limit for a circular section.
Antoine
#6 Posted : Tuesday, October 31, 2017 4:49:27 AM(UTC)
Antoine
Switzerland
Tim?
if it is a limitation, then do not propose the shell function in intersections mode.
This gives confusion.
Thank you.
Antoine
Edited by user Tuesday, October 31, 2017 4:51:10 AM(UTC)  | Reason: Not specified
#7 Posted : Tuesday, October 31, 2017 12:19:36 PM(UTC)
Shelling will fail as well because it is not a valid part. (ambiguous inside/outside surfaces). Because of the ambiguity, I also don't think it is manufacturable.
I did notice that if the sweep profile contained the inside profile, it will sweep. This avoids the subtract or shell post steps. I'll look into this.
Edited by user Tuesday, October 31, 2017 12:20:37 PM(UTC)  | Reason: Not specified
cad'n'stuff
#8 Posted : Wednesday, November 1, 2017 2:26:05 AM(UTC)
cad'n'stuff
Was thanked: 47 time(s) in 23 post(s)
You could try to cut away and repair the self-intersecting part and shell it afterwards
Antoine
#9 Posted : Wednesday, November 1, 2017 3:15:21 AM(UTC)
Antoine
Switzerland
Thank you
Guest (5)
