I have labelled vertices and edges of a triakis truncated tetrahedron, but there is a lot of visual clutter as the labels are not hidden.
Is there a way to make them hide?
Otherwise hiding text is on my wish list for SharkCAD PRO 10.
Thanks in advance.
Jalaluddin
Edited by user Friday, October 20, 2017 10:05:30 PM(UTC)
triakis_tt.sfx
(246kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 176 times Was thanked: 158 time(s) in 108 post(s)
Hi Jalaluddin,
Right Click, Hide All-Text + Dimensions.
(78kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 319 times Was thanked: 192 time(s) in 136 post(s)
If you want that your numbers are hidden by your object and only the numbers in foreground visible you cant use the Option "Screen Horiz". For this you have to create a new Working Plane for every Number for text in 3D Space. That the Screen Horiz. Text should be hidden by the Solid is maybe a good idea and is now also in my wishlist.
