cedarcreekdesigner
#1 Posted : Tuesday, October 17, 2017 4:38:02 PM(UTC)
cedarcreekdesigner
I have a solid object defined. I also have other objects needed to create a 'net surface'. How can i generate the 'edge' of the solid--it is the intersection of two cylinders--in order to define the second of the 'N' curves to create the surface. THEN, how should I convert the surface to a solid so that I can 3D print it?
CCD
PS i can provide the file showing all this if it would help.
#2 Posted : Tuesday, October 17, 2017 5:42:34 PM(UTC)
The Explode Curve tool will convert an existing edge of a surface/solid into a curve.
The Surface/Surface Intersection tool will create a curve at the intersection.
You will need to use the Stitch tool to combine the individual surfaces forming a closed volume and convert into a solid. If it is a thin wall surface, you could thicken the surface into a solid.
Hope this helps, if not post the file!
