Hello! I often have an import from PCB-DWG-Files and must seperate objects to differant layers. What i urgent need is to select objects by color or circles by diameter. Can you program a new selection filter? Best regards Jörg
Hello Jorg Under the drop down menu window is the selection mask tool. If allows selection of colors and types of objects. Regards Jason
Hello Jason, I don`t found the selection tool. My language from VIACAD is in german. In the second drop down menue "edit" is: select all; deselect all, select objects connected together Can you give me some more information, where I can found this selection tool? Thanks in advanced Jörg
Jorg
See attached pic. Its the "Window" Menu second from last.
(62kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 5 times Was thanked: 26 time(s) in 22 post(s)
In V9 heißt das Fenster / Auswahlmaske ... die V10 habe ich in englisch, wird in der deutschen Version ähnlich heißen. Horst
Select Mask as mentioned will support color,layer,type.
>>by diameter.
For same shape selects you would need the Select Same : Shape option in PowerPack.
https://www.youtube.com/...Y50&feature=youtu.be Tim
Edited by user Wednesday, September 27, 2017 2:27:05 PM(UTC)
Hello Tim, Jason, I found your advices and this helps me now in saving me a lot time. Thanks A second question for another problem: After placing text, some letters who have closed lines or arcs, they are filled out? As a sample, the "o" is displayed as a filled circle. My version of viacad 10 pro is release 1341. Have you a solution for this? Thanks in advanced Jörg
