#1 Posted : Wednesday, September 27, 2017 7:04:18 AM(UTC)
Hello!
I often have an import from PCB-DWG-Files and must seperate objects to differant layers. What i urgent need is to select objects by color or circles by diameter.
Can you program a new selection filter?
Best regards
Jörg
#2 Posted : Wednesday, September 27, 2017 9:02:53 AM(UTC)
Hello Jorg
Under the drop down menu window is the selection mask tool. If allows selection of colors and types of objects.
#3 Posted : Wednesday, September 27, 2017 11:28:56 AM(UTC)
Hello Jason,
I don`t found the selection tool. My language from VIACAD is in german.
In the second drop down menue "edit" is: select all; deselect all, select objects connected together
Can you give me some more information, where I can found this selection tool?
Thanks in advanced
Jörg
#4 Posted : Wednesday, September 27, 2017 12:07:48 PM(UTC)
Jorg
See attached pic. Its the "Window" Menu second from last.
horst.w
#5 Posted : Wednesday, September 27, 2017 12:35:15 PM(UTC)
horst.w
In V9 heißt das Fenster / Auswahlmaske ... die V10 habe ich in englisch, wird in der deutschen Version ähnlich heißen.
Horst
#6 Posted : Wednesday, September 27, 2017 2:26:09 PM(UTC)
Select Mask as mentioned will support color,layer,type.
>>by diameter.
For same shape selects you would need the Select Same : Shape option in PowerPack.
https://www.youtube.com/...Y50&feature=youtu.be
Edited by user Wednesday, September 27, 2017 2:27:05 PM(UTC)  | Reason: Not specified
#7 Posted : Thursday, September 28, 2017 2:31:24 AM(UTC)
Hello Tim, Jason,
I found your advices and this helps me now in saving me a lot time.
A second question for another problem:
After placing text, some letters who have closed lines or arcs, they are filled out?
As a sample, the "o" is displayed as a filled circle.
My version of viacad 10 pro is release 1341.
Have you a solution for this?
Thanks in advanced
Jörg
