flatpack
#1 Posted : Monday, September 11, 2017 3:02:24 PM(UTC)
flatpack
Anyone know how to add loop in mesh symmetry?
I have Mesh Symmetry on; and the mirror plane is right in the center facing either side I'm working on.
The push-pull operations are working fine – aka symmetrical.
HOWEVER -- I can't figure out why when I Add Loop to one side, it doesn't reflect on the other side.
Help please..
*using VC 10 Pro. Do NOT have power pack at the moment.
Edited by user Monday, September 11, 2017 3:03:45 PM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, September 12, 2017 11:35:51 PM(UTC)
Would you happen to have a small file that has this issue that you can send me?
You should be able to add a loop with mesh symmetry.
flatpack
#3 Posted : Wednesday, September 13, 2017 7:14:41 AM(UTC)
flatpack
Tim, I sent you the file.
flatpack
#4 Posted : Monday, September 18, 2017 1:28:19 PM(UTC)
flatpack
Hi Tim, did you happen to receive my email with the file? Any good news perhaps? :)
#5 Posted : Monday, September 18, 2017 3:13:41 PM(UTC)
Received, thank you for sending the example file. Unfortunately Add Loop will not add a loop to the symmetry side of the mesh. I'll add this to the feature list.
flatpack
#6 Posted : Monday, September 18, 2017 3:21:06 PM(UTC)
flatpack
ok i understand. Please add thanks -- very useful.
digitalphaser
#7 Posted : Sunday, September 24, 2017 5:00:04 AM(UTC)
digitalphaser
Yes, mesh symmetry(I use viaCAD Pro v10) is very moody. And generally, VC's subdiv feature is suitable only for simple base forms. For more serious work it is less predictable.
flatpack
#8 Posted : Monday, September 25, 2017 9:03:08 AM(UTC)
flatpack
What else can you suggest as an alternative for a Mac user?
1. Modo is too expensive
2. T-splines is no longer available for Rhino
3. Clayoo plugin is only for PC
4. Silo is ok but I don't even think its being developed anymore
5. Maya is too expensive
Hope VC SubD will continue to be developed to a higher degree.. It could be very promising.
digitalphaser
#9 Posted : Monday, September 25, 2017 11:46:53 AM(UTC)
digitalphaser
I'm WIN user and I meant hybrid workflow(subDiv + solid) in same programm.
This feature is perfectly implemented in Fusion 360. I did not work with Fusion. But the tutorial videos are very impressive.
In principle, for simple elements, VC's sudiv is quite suitable. But it is very unstable. Here is an example of "Add Loop" function. Absolutely not predictable. Sorry, it's no good.
digitalphaser
#10 Posted : Monday, September 25, 2017 11:58:18 AM(UTC)
digitalphaser
Originally Posted by: flatpack Go to Quoted Post
4. Silo is ok but I don't even think its being developed anymore...
Silo is one of my favorite programs. Recently, Nevercenter released new cool updates(improved UI, FBX export and more). Maybe soon we'll get the 3. version. I hope. :)
thanks 1 user thanked digitalphaser for this useful post.
flatpack on 4/7/2018(UTC)
Jolyon
#11 Posted : Tuesday, March 6, 2018 4:01:53 PM(UTC)
Jolyon
I cannot get Mesh Symmetry to work at all
Very odd as I've used it in the past, albeit not in anger
Jol
Jolyon
#12 Posted : Tuesday, March 6, 2018 4:08:32 PM(UTC)
Jolyon
I turned it round 90 degrees as I wanted the plane of symmetry going XZ (Y=0)
... but if you do that, it doesn't work
Z is always up for me - I'm a transport guy !!
What am I doing wrong ?
Jol
Jolyon
#13 Posted : Wednesday, March 7, 2018 2:34:58 AM(UTC)
Jolyon
I have the symmetry plane working in one open file - and not working in another.
Guest (10)
