Suggestions
Text selection after moving
Thanks: 46 times Was thanked: 43 time(s) in 30 post(s)
I find I am using this program more and more for workshop drawings. I like to detail my notes on the drawing for the guys. So text entry shortcuts for today, has become my "Thing" :-) So my idea for a tweak At the moment Copy text... CTL C pull away with gripper. type in distance to move. Click on text to highlight and modify Click in text box, highlight text to modify. Type new text Proposal Copy text... CTL C pull away with gripper. type in distance to move. Click on text. "Text is automatically highlighted" Start typing. If you wish to keep the same text just use the arrow keys or mouse to deactivate the highlight. Does this make sense to other users or am I just being OCD?
For the data entry window to activate you need to hit the Tab key after you click on the text. This step is required to differentiate from a short cut key. Tim Copy text... Click on text. Hit Tab Key Start typing.
Thanks: 217 times Was thanked: 164 time(s) in 101 post(s)
Hello, Like Maify I would appreciate an improvement of text edition... I'm dreaming of direct typing in a text box, like in Illustrator, Word, Pages ... or even antique Vellum CAD !
Hi Tim
Thanks for the tip.
The tab key solution works fine for me.
Mark
Originally Posted by: Tim Olson For the data entry window to activate you need to hit the Tab key after you click on the text. This step is required to differentiate from a short cut key. Tim Copy text... Click on text. Hit Tab Key Start typing.
Originally Posted by: jlm ..I'm dreaming of direct typing in a text box, like in..
i also would second "inline" text editing for every text tool. within the "box text" tool is is already working.
Originally Posted by: rokoko i also would second "inline" text editing for every text tool. within the "box text" tool is is already working.
Yes. Actually I don't use the "text box" because it is limited to 1 font, 1 size, 1 style and it is a bit awkward to use (not responding instantly)...
Suggestions
