#1 Posted : Wednesday, August 30, 2017 12:41:41 PM(UTC)
Was thanked: 177 time(s) in 107 post(s)
After almost one hour of calculating, I would like to stop that progress without force-quitting...
Date/Time: 2017-08-30 20:43:53 +0200
OS Version: Mac OS X 10.12.6 (Build 16G29)
Architecture: x86_64h
Report Version: 25
Data Source: Stackshots
Command: SharkCAD Pro 10
Path: /Applications/SharkCAD Pro 10.app/Contents/MacOS/SharkCAD Pro 10
Version: 10.0.0 (1341)
Parent: launchd [1]
PID: 12914
Event: hang
Duration: 1.70s (process was unresponsive for 2804 seconds before sampling)
Steps: 17 (100ms sampling interval)
Hardware model: MacBookPro11,5
Active cpus: 8
Fan speed: 5946 rpm
Timeline format: stacks are sorted chronologically
Use -i and -heavy to re-report with count sorting
Heaviest stack for the main thread of the target process:
17 start + 52 (SharkCAD Pro 10 + 9524) [0x100002534]
17 main + 46 (SharkCAD Pro 10 + 12367278) [0x100bcb5ae]
17 NSApplicationMain + 1237 (AppKit + 24078) [0x7fff8ca8fe0e]
17 -[NSApplication run] + 926 (AppKit + 242651) [0x7fff8cac53db]
17 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 (AppKit + 8136686) [0x7fff8d24c7ee]
17 _DPSNextEvent + 1833 (AppKit + 290077) [0x7fff8cad0d1d]
17 AEProcessAppleEvent + 55 (HIToolbox + 269791) [0x7fff8e548ddf]
17 aeProcessAppleEvent + 312 (AE + 31657) [0x7fff8fe1dba9]
17 dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 39 (AE + 31901) [0x7fff8fe1dc9d]
17 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned int, unsigned char*) + 544 (AE + 32550) [0x7fff8fe1df26]
17 _NSAppleEventManagerGenericHandler + 102 (Foundation + 334199) [0x7fff90a19977]
17 -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 290 (Foundation + 334589) [0x7fff90a19afd]
17 -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 661 (AppKit + 308331) [0x7fff8cad546b]
17 -[NSApplication(NSAppleEventHandling) _handleAEOpenEvent:] + 552 (AppKit + 309273) [0x7fff8cad5819]
17 -[NSApplication _sendFinishLaunchingNotification] + 208 (AppKit + 1606836) [0x7fff8cc124b4]
17 -[NSApplication _postDidFinishNotification] + 297 (AppKit + 1607503) [0x7fff8cc1274f]
17 -[NSNotificationCenter postNotificationName:object:userInfo:] + 66 (Foundation + 26231) [0x7fff909ce677]
17 _CFXNotificationPost + 604 (CoreFoundation + 365916) [0x7fff8efa955c]
17 -[_CFXNotificationRegistrar find:object:observer:enumerator:] + 1827 (CoreFoundation + 369955) [0x7fff8efaa523]
17 ___CFXNotificationPost_block_invoke + 50 (CoreFoundation + 643266) [0x7fff8efed0c2]
17 _CFXRegistrationPost + 427 (CoreFoundation + 643931) [0x7fff8efed35b]
17 __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12 (CoreFoundation + 644188) [0x7fff8efed45c]
17 -[CSIAppDelegate applicationDidFinishLaunching:] + 1208 (SharkCAD Pro 10 + 15376232) [0x100ea9f68]
17 csi_main() + 7284 (SharkCAD Pro 10 + 7560708) [0x100735e04]
17 Perform_Option(short, short) + 335 (SharkCAD Pro 10 + 7566927) [0x10073764f]
17 menu_Tools(short) + 34 (SharkCAD Pro 10 + 7571026) [0x100738652]
17 MenuToolsUIO(short, short) + 210 (SharkCAD Pro 10 + 6986594) [0x1006a9b62]
17 MenuToolsSharkFXUIO(short, short) + 445 (SharkCAD Pro 10 + 6988877) [0x1006aa44d]
17 AUXVIEW_uio() + 127 (SharkCAD Pro 10 + 5407919) [0x1005284af]
17 AUXVIEW_SheetUIO() + 639 (SharkCAD Pro 10 + 5408735) [0x1005287df]
17 DRAWWIZ_uio(short, short&) + 860 (SharkCAD Pro 10 + 7589340) [0x10073cddc]
17 drawwiz_HandleCreateDrawings(short, EntData*, WizClass*, long*) + 808 (SharkCAD Pro 10 + 7591880) [0x10073d7c8]
17 drawwiz_CreateDrawing(EntData*, WizClass*, long*, QList&) + 1960 (SharkCAD Pro 10 + 7597352) [0x10073ed28]
17 drawwiz_CreateViews(EntData*, WizClass*, long*, QList&) + 2492 (SharkCAD Pro 10 + 7601436) [0x10073fd1c]
17 AuxViewClass::Regen() + 361 (SharkCAD Pro 10 + 5266537) [0x100505c69]
17 RegenPHLChildren(AuxViewClass*) + 1078 (SharkCAD Pro 10 + 5277158) [0x1005085e6]
17 GEI_PHLHidden(ViewClass*, short, double, short, QList*, QList*, unsigned char*, short) + 2708 (SharkCAD Pro 10 + 15492628) [0x100ec6614]
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 692126) [0x107630f9e]
17 ??? (<BBA18CC0-B6F4-32BC-B80D-B912D8A77234> + 926717) [0x10827d3fd]
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 753590) [0x10763ffb6]
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 725208) [0x1076390d8]
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 649309) [0x10762685d]
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 656751) [0x10762856f]
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 656833) [0x1076285c1]
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 656963) [0x107628643]
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 734127) [0x10763b3af]
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 734279) [0x10763b447]
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 657647) [0x1076288ef]
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 657760) [0x107628960]
16 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 677822) [0x10762d7be]
2 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 187372) [0x1075b5bec] (running)
Process: SharkCAD Pro 10 [12914]
Parent: launchd [1]
UID: 501
Task size: 2898.60 MB (+16 KB)
CPU Time: 1.608
Note: Unresponsive for 2804 seconds before sampling
Note: 1 idle work queue threads omitted
Thread 0x380c71 DispatchQueue 1 17 samples (1-17) priority 47 (base 47) cpu time 1.600
<process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [623], IO tier 0>
17 start + 52 (SharkCAD Pro 10 + 9524) [0x100002534] 1-17
17 main + 46 (SharkCAD Pro 10 + 12367278) [0x100bcb5ae] 1-17
17 NSApplicationMain + 1237 (AppKit + 24078) [0x7fff8ca8fe0e] 1-17
17 -[NSApplication run] + 926 (AppKit + 242651) [0x7fff8cac53db] 1-17
17 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796 (AppKit + 8136686) [0x7fff8d24c7ee] 1-17
17 _DPSNextEvent + 1833 (AppKit + 290077) [0x7fff8cad0d1d] 1-17
17 AEProcessAppleEvent + 55 (HIToolbox + 269791) [0x7fff8e548ddf] 1-17
17 aeProcessAppleEvent + 312 (AE + 31657) [0x7fff8fe1dba9] 1-17
17 dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 39 (AE + 31901) [0x7fff8fe1dc9d] 1-17
17 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned int, unsigned char*) + 544 (AE + 32550) [0x7fff8fe1df26] 1-17
17 _NSAppleEventManagerGenericHandler + 102 (Foundation + 334199) [0x7fff90a19977] 1-17
17 -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 290 (Foundation + 334589) [0x7fff90a19afd] 1-17
17 -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 661 (AppKit + 308331) [0x7fff8cad546b] 1-17
17 -[NSApplication(NSAppleEventHandling) _handleAEOpenEvent:] + 552 (AppKit + 309273) [0x7fff8cad5819] 1-17
17 -[NSApplication _sendFinishLaunchingNotification] + 208 (AppKit + 1606836) [0x7fff8cc124b4] 1-17
17 -[NSApplication _postDidFinishNotification] + 297 (AppKit + 1607503) [0x7fff8cc1274f] 1-17
17 -[NSNotificationCenter postNotificationName:object:userInfo:] + 66 (Foundation + 26231) [0x7fff909ce677] 1-17
17 _CFXNotificationPost + 604 (CoreFoundation + 365916) [0x7fff8efa955c] 1-17
17 -[_CFXNotificationRegistrar find:object:observer:enumerator:] + 1827 (CoreFoundation + 369955) [0x7fff8efaa523] 1-17
17 ___CFXNotificationPost_block_invoke + 50 (CoreFoundation + 643266) [0x7fff8efed0c2] 1-17
17 _CFXRegistrationPost + 427 (CoreFoundation + 643931) [0x7fff8efed35b] 1-17
17 __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12 (CoreFoundation + 644188) [0x7fff8efed45c] 1-17
17 -[CSIAppDelegate applicationDidFinishLaunching:] + 1208 (SharkCAD Pro 10 + 15376232) [0x100ea9f68] 1-17
17 csi_main() + 7284 (SharkCAD Pro 10 + 7560708) [0x100735e04] 1-17
17 Perform_Option(short, short) + 335 (SharkCAD Pro 10 + 7566927) [0x10073764f] 1-17
17 menu_Tools(short) + 34 (SharkCAD Pro 10 + 7571026) [0x100738652] 1-17
17 MenuToolsUIO(short, short) + 210 (SharkCAD Pro 10 + 6986594) [0x1006a9b62] 1-17
17 MenuToolsSharkFXUIO(short, short) + 445 (SharkCAD Pro 10 + 6988877) [0x1006aa44d] 1-17
17 AUXVIEW_uio() + 127 (SharkCAD Pro 10 + 5407919) [0x1005284af] 1-17
17 AUXVIEW_SheetUIO() + 639 (SharkCAD Pro 10 + 5408735) [0x1005287df] 1-17
17 DRAWWIZ_uio(short, short&) + 860 (SharkCAD Pro 10 + 7589340) [0x10073cddc] 1-17
17 drawwiz_HandleCreateDrawings(short, EntData*, WizClass*, long*) + 808 (SharkCAD Pro 10 + 7591880) [0x10073d7c8] 1-17
17 drawwiz_CreateDrawing(EntData*, WizClass*, long*, QList&) + 1960 (SharkCAD Pro 10 + 7597352) [0x10073ed28] 1-17
17 drawwiz_CreateViews(EntData*, WizClass*, long*, QList&) + 2492 (SharkCAD Pro 10 + 7601436) [0x10073fd1c] 1-17
17 AuxViewClass::Regen() + 361 (SharkCAD Pro 10 + 5266537) [0x100505c69] 1-17
17 RegenPHLChildren(AuxViewClass*) + 1078 (SharkCAD Pro 10 + 5277158) [0x1005085e6] 1-17
17 GEI_PHLHidden(ViewClass*, short, double, short, QList*, QList*, unsigned char*, short) + 2708 (SharkCAD Pro 10 + 15492628) [0x100ec6614] 1-17
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 692126) [0x107630f9e] 1-17
17 ??? (<BBA18CC0-B6F4-32BC-B80D-B912D8A77234> + 926717) [0x10827d3fd] 1-17
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 753590) [0x10763ffb6] 1-17
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 725208) [0x1076390d8] 1-17
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 649309) [0x10762685d] 1-17
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 656751) [0x10762856f] 1-17
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 656833) [0x1076285c1] 1-17
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 656963) [0x107628643] 1-17
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 734127) [0x10763b3af] 1-17
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 734279) [0x10763b447] 1-17
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 657647) [0x1076288ef] 1-17
17 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 657760) [0x107628960] 1-17
2 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 677822) [0x10762d7be] 1-2
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 189803) [0x1075b656b] (running) 1
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 210898) [0x1075bb7d2] (running) 2
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 677830) [0x10762d7c6] (running) 3
14 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 677822) [0x10762d7be] 4-17
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 189803) [0x1075b656b] (running) 4
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 210628) [0x1075bb6c4] (running) 5
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 187384) [0x1075b5bf8] (running) 6
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 210632) [0x1075bb6c8] (running) 7
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 210733) [0x1075bb72d] (running) 8
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 210654) [0x1075bb6de] (running) 9
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 210733) [0x1075bb72d] (running) 10
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 189791) [0x1075b655f] (running) 11
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 210708) [0x1075bb714] (running) 12
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 187451) [0x1075b5c3b] 13
*1 return_from_trap + 160 (kernel + 632144) [0xffffff800029a550] (running) 13
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 210702) [0x1075bb70e] (running) 14
1 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 210628) [0x1075bb6c4] (running) 15
2 ??? (<3838B197-2578-3674-86AB-24C62A260FE5> + 187372) [0x1075b5bec] (running) 16-17
Thread 0x380d33 Thread name "CVDisplayLink" 17 samples (1-17) priority 54 (base 54)
Edited by user Thursday, August 31, 2017 6:29:04 AM(UTC)  | Reason: Not specified
Capture d’écran 2017-08-30 à 20.37.36.png (58kb) downloaded 3 time(s).
