ViaCad 10 - registration issues - "Unable to save..."
                Having a bit of a stumbling block at the moment..
                Anyone? Please help..  Have not heard back from Tim or the Tech-support people..
Maybe everyone is still on summer vacation?
Thanks!
Edited by user  Tuesday, August 29, 2017 11:04:16 AM(UTC)
 | Reason: Not specified
                Originally Posted by: flatpack  Anyone? Please help..
Hello
http://www.punchcad.com/c-26-support Try calling Phone: 800-856-9601
                Thank you Jason, I was able to call them and the tech guy is on vacation.
The other guy there did have some advice and stayed with me on the phone.  Gave me a new SN and while it did say "Registration Successful", the next window that popped up again said reg info was unable to be saved.  See image.
I tried changing permissions on the VC app to Read+Write for everyone, but to no avail.
Also, I can only try 3 times with the SN before it says I've reached the "maximum number of allowed activates"
Originally Posted by: jdi000  Edited by user  Tuesday, August 29, 2017 1:14:26 PM(UTC)
(12kb) downloaded 3  time(s). You cannot  view/download attachments. Try to login or register.
                 "Unable to save registration info for sysprefs"
                Originally Posted by: Tim Olson   "Unable to save registration info for sysprefs"
Noted – that's what I thought that it was a permissions error.  Yes I am logged in as admin.
I'm stuck....
I'm stuck....
*Sorry for posting twice – forgot to log in earlier.
Edited by user  Wednesday, August 30, 2017 11:48:39 AM(UTC)
                What I've done so far:
I understand and thanks for the suggestion. I did try quitting and re-starting to no avail.  I'm using a mac which usually works immediately after install+registration.
The problem happens immediately after I hit the register button.  First a dialog box pops up that says Registration Successful.  I hit the OK button on it.  Immediately following that, a new window pops up that says "Unable to save registration info for sysprefs."  I hit OK again and VC Pro 10 continues to open.
When I go to Preferences>Registration, I can see my name and the Serial Number.
But as soon as I quit out of VC and try to re-open it, the registration is indeed NOT saved and I am stuck being asked to fill everything out again to re-register.
                hi, what you can try is to create an additional completely new user in system preferences -> users (new user with administrator permissions). then login as the new user and try to register again. hope that helps,
                Originally Posted by: rokoko  hi, what you can try is to create an additional completely new user in system preferences -> users (new user with administrator permissions). then login as the new user and try to register again. hope that helps,
Thank you I appreciate the advice – it might work, but I do not have anymore Serial numbers to use..
                Can you private email me your Node Id from Preferences: Registration and I can manually create a serial number that should override the issue you are seeing.
                Im having the same issue occur is this forum still active, is there anyone that can help? Tried calling the number up top, as well as emailing, just not having any luck.
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
