machtool
#1 Posted : Saturday, July 8, 2017 12:45:36 PM(UTC)
machtool
I want create a simple hole at specific coordinate,
When I enter the coordinates in the boxes it does it not put the hole at that point, it puts the hole where ever i click on the solid, what am I doing wrong ?
#2 Posted : Saturday, July 8, 2017 1:19:41 PM(UTC)
Hello machtool
You can select the hole click on inside face of hole and then change the coordinates after the hole is placed.
horst.w
#3 Posted : Sunday, July 9, 2017 9:52:18 AM(UTC)
horst.w
... but this is not running with Counter Bore and Counter Sink.
To place a Simple Hole or the both Counters it is a good solution to create crossing construction lines. The crossing point will be marked as " intersect"-point for center of the hole. Midpoint-guide-line and one construction lines has the same result also as every geometrical construction with arcs and lines.
regards
horst.w, GER
Edited by user Sunday, July 9, 2017 10:07:28 AM(UTC)  | Reason: Not specified
Bohrung verschieben.jpg (72kb) downloaded 8 time(s).
rokoko
#4 Posted : Sunday, July 9, 2017 10:07:36 AM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
Originally Posted by: machtool Go to Quoted Post
When I enter the coordinates in the boxes it does it not put the hole at that point, it puts the hole where ever i click on the solid..
after selecting the solid face click on that face. thereafter you can type your desired coordinates in the data entry area. the hole will move to
