Solid Modeling
Creating a holes at a specific X Y location
I want create a simple hole at specific coordinate, When I enter the coordinates in the boxes it does it not put the hole at that point, it puts the hole where ever i click on the solid, what am I doing wrong ?
Hello machtool You can select the hole click on inside face of hole and then change the coordinates after the hole is placed. Regards Jason
... but this is not running with Counter Bore and Counter Sink.
To place a Simple Hole or the both Counters it is a good solution to create crossing construction lines. The crossing point will be marked as " intersect"-point for center of the hole. Midpoint-guide-line and one construction lines has the same result also as every geometrical construction with arcs and lines.
regards
horst.w, GER
Edited by user Sunday, July 9, 2017 10:07:28 AM(UTC)
(72kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: machtool When I enter the coordinates in the boxes it does it not put the hole at that point, it puts the hole where ever i click on the solid..
after selecting the solid face click on that face. thereafter you can type your desired coordinates in the data entry area. the hole will move to
Solid Modeling
