Holzwurm56
#1 Posted : Monday, July 3, 2017 10:35:17 AM(UTC)
Holzwurm56
Hello,
i create a 3d part with Viacad 10 2d/3d. Now its not more possible to make boolean operations with the part. I can not marker it. Other operations move, mirror, rotating are possible. Is there a maximum of polygons for boolean operations?
Hans
#2 Posted : Monday, July 3, 2017 11:04:34 AM(UTC)
Hello Hans
Is your part a Mesh or Solid? A Solid has no limits to the number of faces that can be used in a boolean operation.
Holzwurm56
#3 Posted : Monday, July 3, 2017 12:54:14 PM(UTC)
Holzwurm56
Hello Tim,
many thanks for your answer. What is the diffrence between solid and meshes? If its meshes, can I convert to solid?
Hans
#4 Posted : Tuesday, July 4, 2017 11:17:23 AM(UTC)
Hello Hans
Meshes are collections of 3 or 4 sided facets created from facet tools or importing stl/obj files. Solids are defined by more complex equations (NURBS/Analytics) and used for modeling operations like blending and shelling.
A quick way to tell what you have is to open Concept Explorer : Entities Tab : All Objects : Selected Only (off). Meshes are usually displayed with a green icon while solids use a blue icon.
Edited by user Tuesday, July 4, 2017 1:21:06 PM(UTC)  | Reason: Not specified
Holzwurm56
#5 Posted : Saturday, July 15, 2017 12:20:14 PM(UTC)
Holzwurm56
Hello Tim,
there is a difference in the german version. It shows only the selected items. The item is named "Facettennetz".
Hans
rokoko
#6 Posted : Saturday, July 15, 2017 1:23:36 PM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
do a right click in a free space in concept explorer to select visible items
Guest (5)
