Suggestions
Copying a Item while working on another Layer destroy the layer attribute of the copy.
Thanks: 326 times Was thanked: 202 time(s) in 140 post(s)
When working on construction layer and Mirroring a object and press ctrl to copy the item, the layer of the item will be broken and just changed to construction layer. The same when just using copy and paste. And the same when using copy and paste of the whole geometry. Copy and paste should keep all attributes of the items.
Solution found: Edit> Paste Options> Preserve Layers
(3kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
see in preferences:
Edited by user Sunday, July 2, 2017 4:30:51 AM(UTC)
(132kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked rokoko for this useful post.
Suggestions
