2D Drafting
SNAPS "perpendicular adjustment question
while attempting to establish a perpendicular with SNAPS from the vertices of a spline curve, some perpendiculars are shown and
most are not .............. how do I adjust the SNAPS perpendicular settings to get perpendiculars from all of the spline's vertices ?? see attached image
Art Smith
artesmith@earthlink.net Art Smith attached the following image(s):
(41kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
in the absence of Aeropack source code, I'm
guessing the "create airfoil" tool uses the selected leading edge and trailing edge to deduce the required chord, then uses a set of equations similar to those found at Airfoil Tools (http://airfoiltools.com/airfoil/naca4digit) to calculate a set of points for the upper and lower surface, and then connects each set of points with a spline. clearly then the spline doesn't pass through each of the points creating a challenge for the "perpendicular snap". if the points along the upper and lower surface defining airfoil spline were equally spaced, the problem could be simply overcome by distributing equally space points along the
spline curves and using them in lieu of the calculated points. the points however are
NOT equally spaced, they're cosine spaced to pack more points into the front of the airfoil where there's more curvature !!!
hence the question on how to "help" the
perpendicular snap tool.................
Art Smith
Was thanked: 523 time(s) in 358 post(s)
Hi Art
The equations for the airfoils came from Theory of Wing Sections. The points that are calculated from the resulting equations are then fit using a B-Spline. They are fit to within 0.0005 inches.
The difference you may see on the screen may be due to the display list. The display list is the visual representation of the equation to the screen.
To get the best displayed curve try using Edit : Resolution : Super Fine: Precise.
This is an option for equal point spacing along the curve (not wrt chord) to complement the cosine distribution. The cosine distribution typically does a better job at the leading edge.
Edited by user Wednesday, June 7, 2017 4:28:49 PM(UTC)
(270kb) downloaded 16 time(s). You cannot view/download attachments. Try to login or register.
>>how do I adjust the SNAPS perpendicular settings to get perpendiculars from all of the spline's vertices ?? LogiCursor perpendiculars are calculated from the current cursor location back to the curve. I'll add in a Perp from location into PowerPack for you, something I have been meaning to do. Tim
Tim-
thanks!! I've used the "equal" spacing option when only a cartoon/graphic is needed; it's cosine spacing whenever parts will be machined to the solid model.
"Theory of Wing Sections" is a great deal more readable than the original NACA reports which will never be mistaken for Tom Clancy or Raymond Chandler.....!!
Art Smith
a "Shout Out" to Tim and the team for the recent changes that fixed my normals problem!! the improved capability/new tools are a
HUGE step forward !!!
Art Smith
(37kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
Awesome!
Video showing the minor tweaks in SharkCAD Pro 1341 for AeroPack: NACA airfoils and new PowerPack: Line Perp.
http://www.csi-concepts.com/Demo/videos/NACA.mp4 Tim
2D Drafting
