xMack
#1 Posted : Wednesday, May 10, 2017 2:46:22 AM(UTC)
xMack
I am working in 2D mode and ViaCAD keeps crashing/locking up whenever I try to extend a line that is enclosed inside of a rectangle or other polygons when using the polygon as the extend to boundary. It works fine if I extend a line inside of a circle, but I can't get it to work in a rectangle or polygons. If I try to extend a line to intersect a polygon, the screen blinks and then I get a blue circle showing that it is trying to do something but it never comes back. I have to close out of ViaCAD and start over. Is this a bug or is it just not possible to use extend inside of a polygon? If it is not possible, it seems like it should give me an error and shouldn't lock the program up.
Anyone else have this issue? Any fix for it?
#2 Posted : Wednesday, May 10, 2017 4:24:41 AM(UTC)
Hello
What version and build are you using check it in the help menu.
Is this just happening in 2d mode?
#3 Posted : Wednesday, May 10, 2017 9:11:28 AM(UTC)
Was thanked: 523 time(s) in 358 post(s)
Would it be possible to provide an example file?
xMack
#4 Posted : Wednesday, May 10, 2017 9:42:24 AM(UTC)
xMack
See attached test file. I can select the circle and then hit the extend button and extend the line inside the circle without any problem. If I select the rectangle or polygon first and them hit the extend button that will lock me up. This happens in both 2D and 3D modes.
I am running ViaCAD Pro 10 Version 10.0.0 Build 1309 in Windows 10 64 bit.
Edited by user Wednesday, May 10, 2017 10:00:58 AM(UTC)  | Reason: Not specified
Extend Test.vcp (5kb) downloaded 11 time(s).
Extend Test.vcp (5kb) downloaded 9 time(s).
#5 Posted : Wednesday, May 10, 2017 10:37:23 AM(UTC)
>> Build 1309
Would it be possible for you to contact Encore TechSupport and request a Work In Progress build? A newer build should correct the crash. They have 1318 available for issues such as this.
Extending to a polygon is something that still needs to be added to the trim tool.
#6 Posted : Wednesday, May 10, 2017 2:19:05 PM(UTC)
Thanks for the help. I have contacted customer support and got the 1318 build.
#7 Posted : Wednesday, May 10, 2017 2:40:46 PM(UTC)
Trimming/extending to polygons is now added to the 1341+ builds.
