Solid Modeling
Extrude and maintain radius of internal angles
I am trying to extrude a shape which has filleted internal sides, at an extrusion offset angle of 8 degrees. The problem is the arcs of the fillets reduce in radius to zero as the extrusion progresses. This would be expected but is there any way to maintain the arcs constant?
Andy Can you post some pics of what you are describing? Not sure what this looks like but can you add the radius after extrusion. Regards Jason
Thanks: 183 times Was thanked: 159 time(s) in 109 post(s)
Hi Andy,
As Jason suggested, an example would be helpful.
You could subtract a tapered solid.
Extrusion.sfx
(103kb) downloaded 9 time(s). L. Banasky attached the following image(s):
(90kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
This shows the issue, the lines should end up parallel rather than the radius tapering and the lines converging, eventually to a point.
andyww attached the following image(s):
(5kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
Andy,
As Jason suggested:
<<<< Not sure what this looks like but can you add the radius after extrusion.>>>>
seems to work well.
Extrusion2.sfx
(31kb) downloaded 10 time(s). L. Banasky attached the following image(s):
(108kb) downloaded 19 time(s). You cannot view/download attachments. Try to login or register.
That is what I need to do. How to do this? Thanks.
Draw the outside and inside lines.
Extrude with 8 degree taper.
Use Constant Blend, and select the corner where the inside
sides meet.
(73kb) downloaded 13 time(s). You cannot view/download attachments. Try to login or register.
When I try this is seems to be applying a fillet to all corners of the selected corner, including the front and back faces.
I have made sure nothing is originally selected, then selecting just the curve in the existing corner does this.
(23kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
OK I have this now. Doing a multi-select works. Thanks!
Solid Modeling
