#1 Posted : Sunday, April 9, 2017 12:57:05 PM(UTC)
Was thanked: 255 time(s) in 168 post(s)
In draftboard it works 1000000 x faster.
#2 Posted : Sunday, April 9, 2017 4:33:19 PM(UTC)
Hello
Are you trying complex geometry or simple objects ?
#3 Posted : Monday, April 10, 2017 11:06:02 AM(UTC)
Simple objects but 100x100
#4 Posted : Monday, April 10, 2017 12:39:03 PM(UTC)
This should now be fixed in 1338+ builds. There was a pre and post process command done for every copied item instead of once per command.
Same for the polar array, it also is significantly faster when using many objects.
Many thanks for the heads up.
Edited by user Monday, April 10, 2017 12:58:48 PM(UTC)  | Reason: Not specified
