Sam
#1 Posted : Tuesday, March 28, 2017 9:36:33 AM(UTC)
Hello,
I'm having trouble getting some things to display properly in my viewports. The first issue I'm having is that objects are appearing in my viewport that have actually been moved and completely modified in my model. I have tried using the show all buttom and turning on all layers to see if the object was in the model, but saw nothing. I closed and reopened the drawing to see if the objects would show up in the model but they did not, but they still showed up when I regenerated the viewport. I'll see if I can attach a picture of it.
Viewport
Here is the model view
Model View
Thanks.
Then there is the angular dimension. Sometimes the arrows move to the other side of the dimension lines. Here is the view of that.
Angular dimension
Help with this would be appreciated.
Thank you
Sam
Sam attached the following image(s):
angle dimension.jpg (69kb) downloaded 14 time(s).
ViaCAD _standard handrail3D TEST model.jpg (69kb) downloaded 15 time(s).
ViaCAD _standard handrail3D TEST.jpg (193kb) downloaded 16 time(s).
#2 Posted : Tuesday, March 28, 2017 12:17:55 PM(UTC)
Was thanked: 523 time(s) in 358 post(s)
Hi Sam
The images did not get uploaded. Would it be possible to attach the ViaCAD file? Also what build are you using? The Build number is in the splash screen.
Sam
#3 Posted : Tuesday, March 28, 2017 12:51:25 PM(UTC)
I am learning how to use the forum, lol. It says v9.0.11 build(1206). I attached the files in the previous post but they got turned 90 degrees.
standard handrail3D TEST.vc3 (1,110kb) downloaded 9 time(s).
Sam
#4 Posted : Tuesday, March 28, 2017 3:36:49 PM(UTC)
I figured out that if I created a new viewport the pieces no longer showed up. Those pieces were in the viewport before, but when I rotated them in the model they rotated a duplicate in the viewport.
