Originally Posted by: CSMD
You are showing me the start and end images ... but how about the steps in between ?
How do I know the chamfer values ?
That is always depending from the goal you want to reach.
Especially your first examble, known is the base-quader ?
The top of this pyramide is also known with its position x an y an z? Symetric or non-symetric to the base quader?
Then I would go this way:
the surface of the quader is visible. Draw with the polygone or the multiline a new polygone by following edge by edge; hide the quader (right mouse key) - the new polygone will be situated on the right place (I hope!)
in Top-view you are drawing now the smaller polygone for the topside directly to its x-y-position on the workplane, change to isometric-view and pull up with the gripper the top-polygone to its end-position Z =
when this is done, skin the both polygons to a solid;
Right mouse key Show All > Solids brings back the base quader on the right position;
Add the both solids with the Add-Tool.
Thats all!
H.
Edited by user Saturday, March 25, 2017 3:12:34 PM(UTC)
