CSMD
#1 Posted : Saturday, March 25, 2017 10:13:59 AM(UTC)
CSMD
Canada
How do I move a vertex or an edge of a solid to match another vertex or edge of another solid ?
horst.w
#2 Posted : Saturday, March 25, 2017 10:56:58 AM(UTC)
horst.w
Please show an example, there are to much possibilities to solve this.
regards
horst.w, GER
PS Magnetics, one of the possibilities: http://forum.punchcad.co...sts&t=8337#post31778
Edited by user Saturday, March 25, 2017 11:01:12 AM(UTC)  | Reason: Not specified
CSMD
#3 Posted : Saturday, March 25, 2017 1:57:37 PM(UTC)
CSMD
Canada
See attached picture ...
CSMD attached the following image(s):
horst.w
#4 Posted : Saturday, March 25, 2017 2:27:47 PM(UTC)
horst.w
Here is one of the similar themes to this probleme: http://forum.punchcad.co...sts&t=8389#post32025
The best and shortes solution is to pull up the quader an then flat the edges with a constant chamfer.
H.
CSMD
#5 Posted : Saturday, March 25, 2017 2:34:49 PM(UTC)
CSMD
Canada
You are showing me the start and end images ... but how about the steps in between ?
How do I know the chamfer values ?
horst.w
#6 Posted : Saturday, March 25, 2017 2:43:07 PM(UTC)
horst.w
For a non-symetric body it will be perhaps the best way the following
Draw with the polygon- or multiline-tool the ground base of the down- an the upside
then skin the solid with the tool.
thanks 1 user thanked horst.w for this useful post.
CSMD on 3/25/2017(UTC)
CSMD
#7 Posted : Saturday, March 25, 2017 2:51:36 PM(UTC)
CSMD
Canada
Great ... with Skin Solid ... Thx.
horst.w
#8 Posted : Saturday, March 25, 2017 3:08:39 PM(UTC)
horst.w
That is always depending from the goal you want to reach.
Especially your first examble, known is the base-quader ?
The top of this pyramide is also known with its position x an y an z? Symetric or non-symetric to the base quader?
Then I would go this way:
the surface of the quader is visible. Draw with the polygone or the multiline a new polygone by following edge by edge; hide the quader (right mouse key) - the new polygone will be situated on the right place (I hope!)
in Top-view you are drawing now the smaller polygone for the topside directly to its x-y-position on the workplane, change to isometric-view and pull up with the gripper the top-polygone to its end-position Z =
when this is done, skin the both polygons to a solid;
Right mouse key Show All > Solids brings back the base quader on the right position;
Add the both solids with the Add-Tool.
Thats all!
H.
Edited by user Saturday, March 25, 2017 3:12:34 PM(UTC)  | Reason: Not specified
horst.w
#9 Posted : Saturday, March 25, 2017 3:26:27 PM(UTC)
horst.w
Sorry to my last post, I have forgotten one step: the new drawn polygone over the edges of the quader must be joined together with the Join tool when using the multi line tool. The polygone itself is a geometrical figure, while the multiline is only an assemble of lines. But even the joining may not be sufficient for some of the tools, it needs perhaps to flip them from "lines" to "polygone" (right mouse key > Change Object Type ...)
H.
Edited by user Saturday, March 25, 2017 3:31:51 PM(UTC)  | Reason: Not specified
Guest (5)
