la mouche
#1 Posted : Thursday, August 30, 2012 6:44:50 AM(UTC)
la mouche
Again and again the same bug in the interpretation of lines in MTS mode.
Here is an example:
http://screencast.com/t/WdffbkBo4
Thank you please correct.
It is impossible to work properly as well and have a serious professional workflow with these bugs.
Cordially.
Antoine
bug MTS.sfx (553kb) downloaded 5 time(s).
appli
#2 Posted : Saturday, October 6, 2012 11:00:02 AM(UTC)
appli
Yes it is a real problem. Every time there is a volume with curves there are errors. Even on objects so simple as cylinders.
A management of blocs as autocad would also be welcome. To be able to modify tens of objects at one time it is important especially in drawing building.
#3 Posted : Saturday, October 6, 2012 11:56:08 AM(UTC)
I cannot open Antoine's file.
Crashing every time :
Process: Shark FX [79638]
Path: /Applications/Shark FX v8 SP1/Shark FX.app/Contents/MacOS/Shark FX
Identifier: com.encore.sharkfxv8
Version: 8.0.1 (1011)
Code Type: X86 (Native)
Parent Process: launchd [24473]
Date/Time: 2012-10-06 19:51:01.835 +0200
OS Version: Mac OS X 10.7.5 (11G56)
Report Version: 9
Interval Since Last Report: 555934 sec
Crashes Since Last Report: 8
Per-App Interval Since Last Report: 22140 sec
Per-App Crashes Since Last Report: 1
Anonymous UUID: 57578F85-13C5-4D86-8080-CB2FA841B540
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000037
VM Regions Near 0x37:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Shark FX v8 SP1/Shark FX.app/Contents/MacOS/Shark FX
__TEXT 0000000000001000-0000000002d15000 [ 45.1M] r-x/rwx SM=COW /Applications/Shark FX v8 SP1/Shark FX.app/Contents/MacOS/Shark FX
Application Specific Information:
objc[79638]: garbage collection is OFF
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_c.dylib 0x90e0578f flockfile + 16
1 libsystem_c.dylib 0x90db8002 fread + 36
2 com.encore.sharkfxv8 0x001b49fe BIN_read_char(__sFILE*) + 82
3 com.encore.sharkfxv8 0x001be62f FILEIO_read_char(long, short) + 67
4 com.encore.sharkfxv8 0x001c0352 FileFlags::DoRead(long, short, short) + 54
5 com.encore.sharkfxv8 0x001c308b readdatabase(FileNameSpec&, short, FileFlags&, double, short, short, short) + 661
6 com.encore.sharkfxv8 0x009186a4 FILE_OpenFromFinder(FileNameSpec, char, short) + 316
7 com.encore.sharkfxv8 0x00ac23a2 ProcessItem(FSSpec*, short) + 568
8 com.encore.sharkfxv8 0x00ac26ea _HandleDocs(AEDesc const*, AEDesc*, short) + 298
9 com.encore.sharkfxv8 0x00ac2784 HandleODOC(AEDesc const*, AEDesc*, long) + 32
10 com.apple.AE 0x93990045 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned long, unsigned char*) + 202
11 com.apple.AE 0x93979b67 _ZL25dispatchEventAndSendReplyPK6AEDescPS_ + 43
12 com.apple.AE 0x93979a54 aeProcessAppleEvent + 253
13 com.apple.HIToolbox 0x96be5a86 AEProcessAppleEvent + 103
14 com.apple.HIToolbox 0x96d73ad1 AEProcessEvent + 162
15 com.apple.HIToolbox 0x96c6c52f HIStdAppHandler::HandleEvent(OpaqueEventHandlerCallRef*, TCarbonEvent&) + 181
16 com.apple.HIToolbox 0x96c6d4ce TEventHandler::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 58
17 com.apple.HIToolbox 0x96d60c0c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
18 com.apple.HIToolbox 0x96bdc313 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602
19 com.apple.HIToolbox 0x96bdb790 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 482
20 com.apple.HIToolbox 0x96bdb5a8 SendEventToEventTargetWithOptions + 75
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9ce77000 - 0x9ce78ff7 libquarantine.dylib (36.7.0 - compatibility 1.0.0) /usr/lib/system/libquarantine.dylib
0x9cf20000 - 0x9cf29fff libc++abi.dylib (14.0.0 - compatibility 1.0.0) /usr/lib/libc++abi.dylib
0x9cf2a000 - 0x9cf30ffd com.apple.CommerceCore (1.0 - 17) /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x9cf31000 - 0x9cf31fff com.apple.Accelerate (1.7 - Accelerate 1.7) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0xba900000 - 0xba91bffd libJapaneseConverter.dylib (54.0.0 - compatibility 1.0.0) /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21ff6 libKoreanConverter.dylib (54.0.0 - compatibility 1.0.0) /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xbb300000 - 0xbb301fff libSymbolConverter.dylib (54.0.0 - compatibility 1.0.0) /System/Library/CoreServices/Encodings/libSymbolConverter.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 2
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 29269
thread_create: 2
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=321.3M resident=165.5M(52%) swapped_out_or_unallocated=155.8M(48%)
Writable regions: Total=274.5M written=54.6M(20%) resident=128.4M(47%) swapped_out=0K(0%) unallocated=146.1M(53%)
REGION TYPE VIRTUAL
ATS (font support) 33.0M
ATS (font support) (reserved) 4K reserved VM address space (unallocated)
CG backing stores 62.4M
CG raster data 512K
CG shared images 3472K
CoreGraphics 8K
CoreServices 2428K
IOKit 168K
MALLOC 146.7M
MALLOC guard page 64K
MALLOC_LARGE (reserved) 1536K reserved VM address space (unallocated)
Memory tag=240 4K
Memory tag=242 12K
Stack 65.0M
VM_ALLOCATE 18.2M
__CI_BITMAP 80K
__DATA 20.5M
__DATA/__OBJC 80K
__IMAGE 528K
__IMPORT 400K
__LINKEDIT 82.2M
__OBJC 1528K
__PAGEZERO 4K
__TEXT 239.1M
__UNICODE 544K
mapped file 154.5M
shared memory 312K
shared pmap 10.1M
TOTAL 843.2M
TOTAL, minus reserved VM space 841.7M
Model: MacPro2,1, BootROM MP21.007F.B06, 8 processors, Quad-Core Intel Xeon, 3 GHz, 16 GB, SMC 1.15f3
Graphics: ATI Radeon X1900 XT, ATY,RadeonX1900, PCIe, 512 MB
Memory Module: DIMM Riser A/DIMM 1, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x0000, 0x000000463732353642363145353830304600
Memory Module: DIMM Riser A/DIMM 2, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x0000, 0x000000463732353642363145353830304600
Memory Module: DIMM Riser B/DIMM 1, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x830B, 0x4D3244324737325455344E4234422D334320
Memory Module: DIMM Riser B/DIMM 2, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x830B, 0x4D3244324737325455344E4234422D334320
Memory Module: DIMM Riser A/DIMM 3, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x0000, 0x000000463732353642363145353830304600
Memory Module: DIMM Riser A/DIMM 4, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x0000, 0x000000463732353642363145353830304600
Memory Module: DIMM Riser B/DIMM 3, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x830B, 0x4D3244324737325455344E4234422D334320
Memory Module: DIMM Riser B/DIMM 4, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x830B, 0x4D3244324737325455344E4234422D334320
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x87), Broadcom BCM43xx 1.0 (5.10.131.36.15)
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Ethernet int©gr© 1, Ethernet, en0
PCI Card: ATY,RadeonX1900, sppci_displaycontroller, Slot-1
Serial ATA Device: ST750LX003-1AC154, 750,16 GB
Serial ATA Device: WDC WD10EADS-00L5B1, 1 TB
Serial ATA Device: WDC WD20EARS-00MVWB0, 2 TB
Serial ATA Device: WDC WD1001FALS-00J7B1, 1 TB
Parallel ATA Device: PIONEER DVD-RW DVR-112D
USB Device: USB 2.0 Hub, 0x1a40 (TERMINUS TECHNOLOGY INC.), 0x0101, 0xfd300000 / 2
USB Device: USB 2.0 Hub, 0x1a40 (TERMINUS TECHNOLOGY INC.), 0x0101, 0xfd340000 / 4
USB Device: USB Receiver, 0x046d (Logitech Inc.), 0xc51a, 0xfd344000 / 9
USB Device: USB 2.0 Hub, 0x1a40 (TERMINUS TECHNOLOGY INC.), 0x0101, 0xfd341000 / 7
USB Device: composite_device, 0x047f (Plantronics, Inc.), 0xc001, 0xfd341400 / 11
USB Device: hub_device, apple_vendor_id, 0x912f, 0xfd500000 / 3
USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd510000 / 6
USB Device: Apple Keyboard, apple_vendor_id, 0x0221, 0xfd512000 / 10
USB Device: Apple Cinema HD Display, apple_vendor_id, 0x9221, 0xfd520000 / 5
USB Device: SoundSticks, 0x05fc (Harman International), 0x7849, 0x3d200000 / 2
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8206, 0x5d200000 / 2
FireWire Device: TBS12T, OTOSTORE, 800mbit_speed
FireWire Device: built-in_hub, 800mbit_speed
FireWire Device: External Disk, DMI, 800mbit_speed
FireWire Device: iSight, Apple Computer, Inc., 200mbit_speed
FireWire Device: unknown_device, unknown_speed
#4 Posted : Saturday, October 6, 2012 12:02:22 PM(UTC)
I crashed again a couple of times to confirm.
When trying to import instead of opening, I get the following message :
Capture d™©cran 2012-10-06 20.00.12.png (24kb) downloaded 5 time(s).
#5 Posted : Saturday, October 6, 2012 2:55:43 PM(UTC)
Mexico
Same thing over here
Luis G.
MacOSX Sequoia 15.7.7
la mouche
#6 Posted : Monday, October 8, 2012 7:02:17 AM(UTC)
la mouche
no crash for me, but same bug with line interpretation with v.1016
Thanks Tim.
#7 Posted : Monday, October 8, 2012 11:29:29 AM(UTC)
Tim,
Can you have a look to the crash with Antoine's file ?
JL
