L. Banasky
#1 Posted : Tuesday, February 14, 2017 10:12:04 AM(UTC)
L. Banasky
I just want a Black wire, I can make a line Black, how can I make a
solid object black, really black, not gray, without rendering.
Black Wire.jpg (57kb) downloaded 11 time(s).
#2 Posted : Wednesday, February 15, 2017 2:45:34 AM(UTC)
Since Velum Solid or CU, for some reason :
-->Black is dark grey
-->White is light grey...
On a Mac,
--> the second pencil on the left (lead) makes a better displayed black
--> the second pencil on the right (mercury) makes a better displayed white
Capture d’écran 2017-02-15 à 09.38.28.png (339kb) downloaded 22 time(s).
Capture d’écran 2017-02-15 à 09.43.56.png (319kb) downloaded 14 time(s).
rokoko on 2/15/2017(UTC)
L. Banasky
#3 Posted : Wednesday, February 15, 2017 4:27:47 AM(UTC)
L. Banasky
Thanks jlm,
I'm on Windows, the thing that I don't understand is that a
line can display as Black, and an object can't.
#4 Posted : Wednesday, February 22, 2017 1:46:39 PM(UTC)
The colors on solids are different then on lines. The solids black or white are alot different then lines. I always wondered why this appears this way?
color solid vs lines.png (32kb) downloaded 12 time(s).
digitalphaser
#5 Posted : Tuesday, February 28, 2017 11:56:52 AM(UTC)
digitalphaser
black is no problem.Deep black you can do via Color--->MORE...
Select a color that RGB values are greater than 0, 0, 0. For example 20, 20, 20.
UserPostedImage
thanks 1 user thanked digitalphaser for this useful post.
L. Banasky on 2/28/2017(UTC)
L. Banasky
#6 Posted : Tuesday, February 28, 2017 2:06:47 PM(UTC)
L. Banasky
Thank you very much digitalphaser,
Is there any chance of helping with the color White.
digitalphaser
#7 Posted : Wednesday, March 1, 2017 4:49:51 AM(UTC)
digitalphaser
White is the same. If you change the reserved Punch white 255, 255, 255 to 253,253,253, you will get a color similar to white. The 3D object can not be absolute white. White is the reflection of the light source.
L. Banasky on 3/1/2017(UTC)
L. Banasky
#8 Posted : Wednesday, March 1, 2017 9:29:36 AM(UTC)
L. Banasky
Thanks again digitalphaser,
I don't understand why it works, but it does.
