la mouche
#1 Posted : Tuesday, August 14, 2012 7:53:50 AM(UTC)
la mouche
hello,
I like to know which software to use to model this kind of volume?
Thank you in advance. :):)
Antoine
BPL-RFE
#2 Posted : Tuesday, August 14, 2012 8:57:27 AM(UTC)
BPL-RFE
Hello Antoine.
I know Shapes like this from the Works of [URL="http://www.bathsheba.com/downloads/"]Bathsheba Grossmann[/URL].
He mentions on his homepage the Use of [URL="http://www.wolfram.com/mathematica-home-edition/"]Mathematica[/URL], which can export to STL.
But that is commercial and quite expensive.
I don't know if [URL="http://www.scilab.org/"]SciLab[/URL] (open source) can do the same.
Freeware/Opensource ?
Well, maybe try [URL="http://www.incendia.net/index.html"]Incendia and Geometrica[/URL] for first steps.
And don't forget to come back and report if you are successful ...
Good Luck.
Roland
Krystyn
#3 Posted : Tuesday, August 14, 2012 10:33:05 AM(UTC)
Krystyn
Topmod 3d is known to make this kind of objects. It is free. https://sites.google.com/site/topmod3d/
#4 Posted : Tuesday, August 14, 2012 1:35:43 PM(UTC)
I have a couple of TopMod files in my test database for converting meshes to NURBs. One is a Klein bottle and a "boned" Klein model, see attached image. I split the bottle so you can see inside.
la mouche
#5 Posted : Tuesday, August 14, 2012 2:06:40 PM(UTC)
la mouche
thank you very much :) I'll try it all.
I forgot to mention that I work on MAC.
Antoine
BPL-RFE
#6 Posted : Thursday, August 16, 2012 4:38:56 AM(UTC)
BPL-RFE
Antoine
We are lucky ...
Mathematica supports MAC (but as mentioned it costs money).
BTW:
If you are searching for more inspiration maybe you should try
[URL="http://www.bugman123.com/index.html"]this site[/URL].
Roland
#7 Posted : Thursday, August 16, 2012 11:49:50 AM(UTC)
Wow!
BPL-RFE
#8 Posted : Monday, September 17, 2012 8:34:36 AM(UTC)
BPL-RFE
Hello.
I knew that there is an open source software similiar to Mathematica
out there.
By pure Luck, i found it again:
[URL="http://k3dsurf.sourceforge.net/"]K3DSurf[/URL]
Runs on Windows/MacOSX/Linux ...
Roland
la mouche
#9 Posted : Monday, September 17, 2012 2:49:47 PM(UTC)
la mouche
Antoine
