ipc1-de
#1 Posted : Saturday, February 11, 2017 10:09:22 AM(UTC)
ipc1-de
I want to shorten objects and then reunite them. How do I do that?
See attached screenshot.
Markus
ipc1-de attached the following image(s):
ViaCAD 10 PRO + PowerPack / MAC OSX 10.12 Sierra
rokoko
#2 Posted : Saturday, February 11, 2017 11:46:50 AM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
you can do a split solid:
1) select "infinite plane" and place an infinite plane on your solid
2) split the solid at the plane
3) move part two into part one with gripper
4) add both solids
ipc1-de
#3 Posted : Saturday, February 11, 2017 2:57:05 PM(UTC)
ipc1-de
Thank you!
Das hat ja gut geklappt :)
Danke
murray
#4 Posted : Saturday, February 11, 2017 5:57:30 PM(UTC)
murray
You can use the move face tool to move the end faces of the object along the axis of the central cylinder without cutting and reuniting.
horst.w
#5 Posted : Sunday, February 12, 2017 2:41:48 AM(UTC)
horst.w
There is no doubt about it, the tools of the Solid-Direct-Edit menue (Push-Pull icon) are really powerfull but I don't see how to solve a problem as shown by iPC1-Markus without cutting, when the long and the short part build one objekt.
Yesterday I had a similar problem, I had to shorten an object between 2 points (i.e. the pic, from the 57,xxx mm to 50,0 mm) without changing the rest.
horst.w, GER
murray
#6 Posted : Sunday, February 12, 2017 6:04:54 AM(UTC)
murray
Not push/pull, move face tool. I'm on PC, so if you're Mac and Mac's different I won't know, but hold shift and select ALL of the faces that are going to be moved, one at a time won't work, and define the transformation.
Edited by user Sunday, February 12, 2017 6:10:16 AM(UTC)  | Reason: Not specified
move faces.png (12kb) downloaded 8 time(s).
horst.w
#7 Posted : Sunday, February 12, 2017 2:53:30 PM(UTC)
horst.w
Ok, many thanks for the informations
horst
