la mouche
#1 Posted : Tuesday, October 30, 2012 10:15:16 AM(UTC)
la mouche
Hello
how can we remove this dot? please
thank you
#2 Posted : Tuesday, October 30, 2012 11:20:33 AM(UTC)
You can hide by using the dimension property linear- . "no decimal"
la mouche
#3 Posted : Wednesday, October 31, 2012 3:25:02 AM(UTC)
la mouche
:) no no no, I want the decimal when the dimensions are [COLOR="red"]not[/COLOR] rounded.
see my image.
What I mean is that Shark does not put the dot when the dimension is without decimals automatically.
Otherwise I should do it manually for all dimensions without decimal places.
Must add a function in Shark any dot during round dimensions.
dot only with decimals.png (10kb) downloaded 6 time(s).
mikeschn
#4 Posted : Wednesday, October 31, 2012 9:28:37 AM(UTC)
mikeschn
Perhaps Tim needs to add something similar to this:
Unchecking the trailing Zero's will get rid of the 0's and the decimal point at the same time!
Mike...
mikeschn
#5 Posted : Wednesday, October 31, 2012 11:12:59 AM(UTC)
mikeschn
Strike that last message. Page 47 of the VC8 user manual seems to cover this.
It has the option to turn off leading and trailing zeros, and the example shown doesn't have a period after the 12. I can't test it til I go home, but here is the page...
mikeschn
#6 Posted : Wednesday, October 31, 2012 4:04:23 PM(UTC)
mikeschn
Well, that didn't work. Unchecking the trailing zero's did not get rid of the period.
And switching the Linear to "No decimals" shows 12, but if the line changes to say 12.125, the dimension still says 12.
Not the best situation!
Mike...
