L. Banasky
#1 Posted : Tuesday, December 20, 2016 10:28:22 AM(UTC)
L. Banasky
Was thanked: 149 time(s) in 102 post(s)
SharkFX PC Win 10 Build 1221, simple hole works well on 1 side,
but not the other side.
Strange that it shows up in 'Concept Explorer'.
Vise.sfx (1,376kb) downloaded 8 time(s).
No hole on opposite side.jpg (194kb) downloaded 22 time(s).
murray
#2 Posted : Tuesday, December 20, 2016 3:29:29 PM(UTC)
murray
I deleted the feature and redid it with no issue, no anomaly.
L. Banasky
#3 Posted : Tuesday, December 20, 2016 5:39:10 PM(UTC)
L. Banasky
Thanks Murray,
I still can't put a hole on both sides, would it be possible for you to post
your file? Are you using Build 1221?
Edited by user Tuesday, December 20, 2016 5:42:08 PM(UTC)  | Reason: Not specified
murray
#4 Posted : Tuesday, December 20, 2016 10:50:58 PM(UTC)
murray
I was using 1217, so I downloaded and installed 1221, and got the same as you, Larry. Then I opened the file that I'd modified in 1217, it had holes both sides. I suppressed the last hole then unsuppressed it and it didn't reappear. Quirky!
Edited by user Tuesday, December 20, 2016 10:54:02 PM(UTC)  | Reason: Not specified
