KSimmons
#1 Posted : Tuesday, December 13, 2016 4:49:08 PM(UTC)
KSimmons
Hi there, I need to build simple 3D buildings for placement into X-Plane 11 Flight Simulator. I thought about using primitives or use the architectural tools. Need to export with maybe .obj or SAT file into AC3D. AC3D needs to generate a X-Plane Obj8 file. I think the primitives would have a smaller file size. I have attached a picture of the building I need to build. Also need to build the mound that the building is on.
#2 Posted : Tuesday, December 13, 2016 5:50:58 PM(UTC)
You can draw the building walls and then use the 3d wall tool and roof tool to make buildings.
Then export as dxf, obj, vrml.
I attached files you can try.
build1.zip (27kb) downloaded 8 time(s).
build1.vcp (37kb) downloaded 10 time(s).
KSimmons
#3 Posted : Monday, December 19, 2016 2:03:18 PM(UTC)
KSimmons
Thanks, I thought I had replied earlier, I know I had downloaded your files about a day later, anyway I haven't used the roof tool, I sure have mentioned that the roof in the picture is "flat on top", actually it's sunk down in order to hide the A/C unit , I think. Can the roof tool make a roof that is pyramid shape and the top portion is cut off.
