2D Drafting
SharkFX and mts mode - please!!! (#4797)
Hello Tim and co,
I repeat an action that still has the same bug for many years.
Indeed, SharkFX is not able to interpret correctly MTS mode: model to sheet
There are many errors in the projection in 2D engineering drawings and translation of hidden lines, visible, etc..
Currently it is so unusable, I have to use another program for my engineering plans with an export model built with SharkFX. This is absurd and I would love it to be repaired.
http://www.screencast.com/t/PBNIS3NBx Thank you in advance and long live Shark!
Antoine
cube and mts.sfx
(1,682kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Will look into in the 1084 build coming up this weekend. Tim
Thanks: 231 times Was thanked: 183 time(s) in 110 post(s)
Hi Antoine, I used Beta V9 today to do MTS. Good news : some of the "historical" bugs have been solved ! And it is faster... Promising.
The SDK does not handle occluded dashed/visible line segments very well. I'm gradually rewriting that portion. Tim
2D Drafting
