jbskaggs
#1 Posted : Wednesday, November 30, 2016 3:51:25 PM(UTC)
jbskaggs
how do i install my power pack pro 10?
PRP
#2 Posted : Sunday, December 11, 2016 10:16:35 AM(UTC)
PRP
Same question, bought it with ViaCad Pro 10....
L. Banasky
#3 Posted : Sunday, December 11, 2016 1:50:40 PM(UTC)
L. Banasky
Was thanked: 158 time(s) in 108 post(s)
The way that I used for Shark FX, might be the same for your version, is to rename
RegInfo.ini to RegInfo.old , and restart program.
It will think it is a Demo, enter your new Registration Information that was sent to you.
Authorize and restart, PowerPack should be there.
#4 Posted : Sunday, December 11, 2016 9:50:39 PM(UTC)
Run your PowerPack Pro installer. This will place a license file on your machine. Your next launch of ViaCAD/Shark will then display the PowerPack menu.
HarveyC
#5 Posted : Wednesday, December 14, 2016 9:28:53 AM(UTC)
HarveyC
Tim's method did not work for me (Windows 10 64bit) the program does NOT appear to install the license file, in spite of several retries. But I have just found a manual way to do it:-
1) Unzip PowerPack10.exe to a folder somewhere on your PC.
2) In this folder, under the path \C_\ProgramData\Application Data\Punch!\PowerPack, there is a file called PowerPack10.ini, copy this to C:\ProgramData\Punch!\PowerPack\.
HArvey
dejavu4you
#6 Posted : Friday, July 14, 2017 8:20:25 AM(UTC)
dejavu4you
HArvey
I has the same problem but after change the patch files powerpack 10 not work for me because i didnt do upgrade of the software (ViaCADPro10_1309_PDRM). On the build version 1341 working well
