PowerPack
how do i install my power pack pro 10?
Thanks: 22 times Was thanked: 8 time(s) in 8 post(s)
Thanks: 3 times Was thanked: 2 time(s) in 2 post(s)
Same question, bought it with ViaCad Pro 10....
Thanks: 171 times Was thanked: 157 time(s) in 107 post(s)
The way that I used for Shark FX, might be the same for your version, is to rename
RegInfo.ini to RegInfo.old , and restart program.
It will think it is a Demo, enter your new Registration Information that was sent to you.
Authorize and restart, PowerPack should be there.
(47kb) downloaded 29 time(s). You cannot view/download attachments. Try to login or register.
Was thanked: 503 time(s) in 353 post(s)
Originally Posted by: jbskaggs how do i install my power pack pro 10?
Run your PowerPack Pro installer. This will place a license file on your machine. Your next launch of ViaCAD/Shark will then display the PowerPack menu.
Tim's method did not work for me (Windows 10 64bit) the program does NOT appear to install the license file, in spite of several retries. But I have just found a manual way to do it:- 1) Unzip PowerPack10.exe to a folder somewhere on your PC. 2) In this folder, under the path \C_\ProgramData\Application Data\Punch!\PowerPack, there is a file called PowerPack10.ini, copy this to C:\ProgramData\Punch!\PowerPack\. Regards HArvey
Originally Posted by: HarveyC Tim's method did not work for me (Windows 10 64bit) the program does NOT appear to install the license file, in spite of several retries. But I have just found a manual way to do it:- 1) Unzip PowerPack10.exe to a folder somewhere on your PC. 2) In this folder, under the path \C_\ProgramData\Application Data\Punch!\PowerPack, there is a file called PowerPack10.ini, copy this to C:\ProgramData\Punch!\PowerPack\. Regards HArvey
I has the same problem but after change the patch files powerpack 10 not work for me because i didnt do upgrade of the software (ViaCADPro10_1309_PDRM). On the build version 1341 working well
PowerPack
