Solid Modeling
WorkPlane alignment with arbitrary infinite plane ???
can someone show/tell me how to align Shark FX 9's "WorkPlane" with an arbitrary infinite plane??
the specific case I have is a number of equally spaced infinite planes along a 3D spline. the
starting and ending planes are well understood; it's everything in between that's a mystery.
thanks
Art Smith
artesmith@earthlink.net Art Smith attached the following image(s):
(41kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hovering the cursor on the planes and toggling the C key will do it.
Thanks: 8 times Was thanked: 76 time(s) in 38 post(s)
Under the menu "Workplane" select "Select objects" then click on the infinite plane desired. Mitch
thanks guys!! knew there had to be a way. I keep forgetting planes are "objects"; must be my F77 roots............
Art
artesmith@earthlink.net Edited by user Monday, November 21, 2016 2:53:20 PM(UTC)
Solid Modeling
