hole thread viacad or shark
Hello Is possible in viacad or shark create a thread hole but with 2d symbol of thread (the arc symbol rapresentation). Thank you Bye
I have found a solution :-) I created a scalable 2d symbol with a drill diameter reference. Solution simple and fast.
Thanks: 183 times Was thanked: 159 time(s) in 109 post(s)
Shark has had symbols for a long time. I have used Shark for a long time.
I have never figured out how to use the threaded hole symbols.
Try using a threaded hole in Model-to-Sheet, drag it into your view and
the dashed lines turn into solid lines, and can not be edited or even selected.
Please share with us your method of placing threaded holes in a Model-to-Sheet
drawing.
Your method will be greatly appreciated.
(101kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 2 times Was thanked: 32 time(s) in 26 post(s)
They drag and drop from CE, I can select and edit line type, weight, scale, although these are all global settings, not individual elements, and they display as they're represented in the library. Win 7 & 8.
Thanks Murray, I found out that you can 'Right-Click' and 'Ungroup' after drag and drop into Model-to-Sheet views, then the symbol can be edited. Larry
with deep select tool you can edit objects inside a group without ungrouping
1 user thanked rokoko for this useful post.
Thanks Rokoko,
In the Model-to-Sheet view 'Deep Select' seems to select the whole symbol.
I only want to select the outer circle, and change back to a 'Dashed' line.
After 'Deep Select' all the lines change to 'Dashed'.
(83kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
