la mouche
#1 Posted : Friday, November 8, 2013 12:07:20 PM(UTC)
la mouche
hello,
I need your help :)
What is the best way to model a bust for display? please
Thank you in advance.
Antoine
memphisjed
#2 Posted : Monday, November 11, 2013 5:23:32 AM(UTC)
memphisjed
Was thanked: 16 time(s) in 14 post(s)
To be proper I might pull out one of the old how to draw figure drawing books, and follow those directions.
being to draw fast a representation, simplify:
draw cl profile of chest
extrude
cl bend slightly along the vertical axis.
draw front of chest shape, terminating vertical sections about arm height
extend verticles high.
extrude into chest.
draw cylinder for neck.
hide cylinder.
equal chest profile solid and front shape solid.
unhide neck and add to solid.
fillet seam.
fillet shoulder blades (one ellipse fillet nice, the other refused, so I just radialled)
bust2.vcp (348kb) downloaded 6 time(s).
#3 Posted : Tuesday, November 12, 2013 9:07:19 AM(UTC)
Mexico
I recommend to use surface blending, mor organic shapes can be acquire with this method, a little bit more time consummating maybe, here it is an approach
[ATTACH]4795[/ATTACH]
bustdisplay.sfx (1,179kb) downloaded 6 time(s).
MacOSX Sequoia 15.7.7
la mouche
#4 Posted : Tuesday, November 12, 2013 10:35:26 AM(UTC)
la mouche
thank you very much for your help! :)
I tried an approach to volume types.
This works well and prevents errors tears, typical work surfaces.
What do you think?
Antoine
bust2.sfx (1,365kb) downloaded 6 time(s).
Capture d™©cran 2013-11-12 17.31.01.png (151kb) downloaded 6 time(s).
memphisjed
#5 Posted : Tuesday, December 3, 2013 3:06:10 AM(UTC)
memphisjed
how did you get the skin solid command to rail on the splines?
la mouche
#6 Posted : Tuesday, December 3, 2013 5:05:49 AM(UTC)
la mouche
hello,
Like this:
Capture d™©cran 2013-12-03 12.05.03.png (26kb) downloaded 6 time(s).
#7 Posted : Monday, December 9, 2013 7:46:26 PM(UTC)
Is that second optin on the Skin Solid tool in SFX? I have Shark LT, and do not see that second icon. Looks like it is for rail sweeps.
memphisjed
#8 Posted : Wednesday, December 18, 2013 6:17:13 AM(UTC)
memphisjed
I have vcp and do not see it. It looks useful.
