Thanks: 2 times Was thanked: 32 time(s) in 26 post(s)
Hi Tim and users,
How can I do to this operation?
Thank you.
Antoine
test.sfx
(204kb) downloaded 14 time(s). Antoine attached the following image(s):
(167kb) downloaded 18 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 153 times Was thanked: 149 time(s) in 102 post(s)
Don't know if this this what you were looking for, but I tried.
test 1.sfx
(933kb) downloaded 6 time(s). L. Banasky attached the following image(s):
(78kb) downloaded 14 time(s). You cannot view/download attachments. Try to login or register.
Interresting! :) thank you L. Antoine
You've created a paradox: some of the surfaces don't split the solid. The picture shows the inconsistencies that don't separate the solid.
(104kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
thank you Murray, But I do not think it's because of surfaces. Even if you enlarge the surfaces, and they well intersects the volume, it will not. Antoine
This is your file modified to show that some of the surfaces don't cut the solid into two pieces. I suppose there's a case to make that it should be possible to split the solid with two discrete surfaces where they're selected together, but Shark can't do it currently, which is why I replaced some of your originals with ruled surfaces. The two remaining surfaces that I circled in the pic above don't cut the solid into two.
Edited by user Wednesday, October 19, 2016 2:29:18 PM(UTC)
test1.sfx
(285kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
Hello, Murray thank you :) Indeed, good idea junction surfaces. Antoine
