Antoine
#1 Posted : Wednesday, October 19, 2016 3:18:34 AM(UTC)
Antoine
Switzerland
Was thanked: 32 time(s) in 26 post(s)
Hi Tim and users,
How can I do to this operation?
Thank you.
Antoine
test.sfx (204kb) downloaded 14 time(s).
Antoine attached the following image(s):
Capture d’écran 2016-10-19 à 11.15.12.png (167kb) downloaded 18 time(s).
L. Banasky
#2 Posted : Wednesday, October 19, 2016 5:22:27 AM(UTC)
L. Banasky
Was thanked: 158 time(s) in 108 post(s)
Don't know if this this what you were looking for, but I tried.
test 1.sfx (933kb) downloaded 6 time(s).
Test 1.jpg (78kb) downloaded 14 time(s).
Antoine
#3 Posted : Wednesday, October 19, 2016 6:21:22 AM(UTC)
Antoine
Switzerland
Interresting!
thank you L.
Antoine
murray
#4 Posted : Wednesday, October 19, 2016 6:25:58 AM(UTC)
murray
You've created a paradox: some of the surfaces don't split the solid. The picture shows the inconsistencies that don't separate the solid.
split problem.JPG (104kb) downloaded 15 time(s).
Antoine
#5 Posted : Wednesday, October 19, 2016 6:49:35 AM(UTC)
Antoine
Switzerland
thank you Murray,
But I do not think it's because of surfaces.
Even if you enlarge the surfaces, and they well intersects the volume, it will not.
Antoine
murray
#6 Posted : Wednesday, October 19, 2016 2:25:40 PM(UTC)
murray
This is your file modified to show that some of the surfaces don't cut the solid into two pieces. I suppose there's a case to make that it should be possible to split the solid with two discrete surfaces where they're selected together, but Shark can't do it currently, which is why I replaced some of your originals with ruled surfaces. The two remaining surfaces that I circled in the pic above don't cut the solid into two.
Edited by user Wednesday, October 19, 2016 2:29:18 PM(UTC)  | Reason: Not specified
test1.sfx (285kb) downloaded 8 time(s).
Antoine
#7 Posted : Tuesday, October 25, 2016 3:09:47 AM(UTC)
Antoine
Switzerland
Hello,
Murray thank you :)
Indeed, good idea junction surfaces.
Antoine
